Equipment & Tools From test equipment to hand tools
Stripping for enameled wire. My little know-how.
Old 15th March 2019, 01:53 PM   #21
Pano is offline Pano  United States
Pano's Avatar
It's certainly very fast!
Take the Speaker Voltage Test!
Old 15th March 2019, 02:39 PM   #22
jameshillj is offline jameshillj  Australia
Ur you can get an enamel stripping machine for as little as $40, and better ones for about 100...
Old Yesterday, 10:29 AM   #23
Zampotech is offline Zampotech  Russian Federation
Originally Posted by trobbins View Post
Was the technique aiming to induce an eddy current (and using skin effect) around the circumference of the single copper wire (along a certain length of the wire), and hence raise the copper wire skin temperature rapidly to a point where the enamel melts/burns/expands and smokes, and then allows the enamel to be quickly wiped off whilst it is still somewhat hot?
Did you change the frequency, or find it of most use with that range of wire diameters? And what was the frequency?
Did you get to melt the copper at all, or the parts used to generate the field, during prototyping?
Yes, only the surface layer is supposed to be heated.
Adjustment is made by exposure time. The oscillator frequency is approximately 950 kHz.
At long exposure copper is heated to a white glow and melts.
Click the image to open in full size.Click the image to open in full size.
The photo shows the exposure time control
If you're talking about the type tool ABISOFIX, it handles thick wire. Thin wires unfortunately can break.
Old Yesterday, 10:52 AM   #24
trobbins is offline trobbins  Australia
trobbins's Avatar
Zampotech, thanks for response. Your photo links aren't working.
I guess if melt temp is 1,000C and and you were after 400C then exposure time is about 40%, given adiabatic heating of just the copper surface.
Do you have a photo of the interface ferro transformer that indicates the main winding and where the wire being heated is located ?
Regards, Tim
Old Yesterday, 11:03 AM   #25
I selected the exposure time experimentally. For wires of the same diameter, but with different varnish time is slightly different.
Photo not applied. The working area is a slit 0.6 mm wide
Old Yesterday, 11:13 AM   #26
trobbins's Avatar
Is 0.6mm the effective core gap length?
Old Yesterday, 11:21 AM   #27
No, width 10 mm, clearance 0.6 mm.
the wire is processed to a length of 10 mm
Stripping for enameled wire. My little know-how.Hide this!Advertise here!
Magnet Wire 10 AWG Gauge Enameled Copper 1.5lb 47ft 200C Magnetic Coil Winding Paladinxxx Swap Meet 1 19th March 2014 05:04 PM
ENAMELED CuNi44 0.1mm diameter (Constantan, Isotan) Resistance wire ryanj Swap Meet 25 22nd August 2013 12:24 PM
Speaker Wire vs. Enameled Wire MisterCasual Parts 58 24th March 2013 01:18 AM
AWG 34 enameled wire jkeny Parts 0 8th March 2007 02:24 PM
Chemical Stripping Agent for Magnetic Wire mbcouple Parts 8 20th January 2005 10:44 AM
Copyright ©1999-2019 diyAudio
