Equipment & Tools From test equipment to hand tools
Sanity-check + end-result: a x 1000 measurement preamplifier
Old 18th January 2019, 09:23 PM   #31
Elvee is offline Elvee  Belgium
Elvee's Avatar
Originally Posted by syn08 View Post
Not sure why you think the PSRR potential issue depends on the op amp only.
It doesn't of course, but getting meaningful results either means a global simulation using the right models for all the critical components, or a way to disentangle the contributions of each one to be able to compare the two options (the ground-referenced one could superior, but it also contributes to the leakage of the PS noise)
Originally Posted by gerhard View Post
With this construction you can check how noise on VCC impairs your
input noise density. 60 Ohms is 1nV/rtHz; the VCVS adds it to the clean VCC
with a scale factor of your choice. The 0.1uV offset avoids a LTspice hickup.
Setting E1 = 10 adds 10 nV/rtHz to the clean VCC.
To see the contribution of the VCC noise, just click on the 60 Ohm resistor
when plotting noise density.
Thanks for the tip, it is neat and simple.
I already thought about it, but the solutions I had found were more clunky and far less convenient.
I tested it, and to get a significant impact at 1Hz, I need a factor of 10,000 or 10µV/rtHz. At 1 kHz, it remains relatively insignificant.
That is valid for the AD823 only, but the LF357 would need to be 10's of dB worse to make a difference with more realistic levels.
Sanity-check + end-result: a x 1000 measurement preamplifier-lna21-png
In addition, the passive supply filter is not present.
When it is, the noise at 1Hz remains unchanged, logically, but between 10Hz and the rest, it is essentially wiped out (not that it actually matters, but it is good to know)
Sanity-check + end-result: a x 1000 measurement preamplifier-lna22-png
Edit:
I just checked, and in fact the 823 is significantly worse on PSRR than the 357, something I never imagined, but it certainly puts the issue to rest
. .Circlophone your life !!!! . . ♫♪ My little cheap Circlophone© ♫♪
Electrify your daily life!!! ....⚡⚡ ELEKTRIA ⚡⚡
Old 18th January 2019, 09:44 PM   #32
gerhard is online now gerhard  Germany
gerhard's Avatar
Methinks that should be V(onoise) / gain to see the noise density effect at the input.
gain is predeclared.
"That's right!" shouted Vroomfondel, "we demand rigidly defined areas of doubt and uncertainty!" "We don't demand solid facts! What we demand is a total absence of solid facts. I demand that I may or may not be Vroomfondel!"
Old 18th January 2019, 09:52 PM   #33
syn08 is offline syn08  Canada
syn08's Avatar
Not sure why you cling so hard on the op amp PSRR performance. The noise source due to the imbalanced op amp inputs contribution is outside of the op amp and PSRR of the op amp is largely irrelevant. It's the op amp CMRR that matters much more. Ideally, only the imbalances to the op amp inputs will be amplified.
Old 18th January 2019, 10:48 PM   #34
Elvee's Avatar
Indeed (I am a bit tired), and LTspice can in fact plot it directly, but the individual contributions are always referred to V(onoise), meaning that to make comparisons, one still needs to enter the gain for other traces:
Sanity-check + end-result: a x 1000 measurement preamplifier-lna23-png
It brings the contribution of the supply noise to 1.6pV/rtHz@1kHz for 10µV/rt/Hz, which makes it even more irrelevant, but it matters even less.
My mistake: I meant CMRR (I am decidedly tired), which is much worse for the 823 than for the 357.
Old 2nd February 2019, 04:26 PM   #35
jackinnj is offline jackinnj  United States
jackinnj's Avatar
I changed out the opamps to OPA637 and simmed in TINA:
Sanity-check + end-result: a x 1000 measurement preamplifierHide this!Advertise here!
sanity check CharlieM Planars & Exotics 31 1st October 2018 03:24 AM
3-way sanity check Mayuri Multi-Way 9 29th August 2017 01:05 PM
2-Way Sanity Check wrenchone Multi-Way 8 9th December 2011 08:54 PM
Sanity Check ..... please Lostcause Digital Source 0 16th October 2008 07:19 PM
Sanity check planet10 Multi-Way 14 7th March 2004 11:15 PM
Copyright ©1999-2019 diyAudio
