Equipment & Tools From test equipment to hand tools
Amber Distortion Meter Readings
Old 8th November 2018, 04:48 PM   #11
Chamberman is offline Chamberman  United States
I do own a pair of them. A 3501 & 3501A. The 3501A came with the 358 digital freq meter on it which is a nice addition. It'll display freq's up to 1MHz which is well above the 3501's measurement capability.
If you haven't replaced the tantalum caps in yours yet then you should do that immediately. Its just a matter of time before one of them shorts out. I didn't replace the tants on the input board of one of my 3501s (I planned to but forgot) and of course one of them started smoking on me a few months ago.
KC
Old 8th November 2018, 06:27 PM   #12
KenwoodM2A is offline KenwoodM2A  Canada
KenwoodM2A's Avatar
Originally Posted by 1audio View Post
Speaking of high distortion .5% from a tuner is pretty high. However it maybe leakage of the subcarrier beacon at 19 KHz. You should follow the instructions for tuning the trap before making any measurements. .01% with a significant signal level is quite attainable with a decent FM tuner.
Actually the deck that I refurbished and aligned is an old Kenwood KRC-939 Car deck. I am in the process of checking the alignment of the tuner and adjusting as required. Everything was pretty much dead on from factory settings of the pots. The final distortion level is .35 %
Old 8th November 2018, 06:37 PM   #13
KenwoodM2A's Avatar
Someone else who has one of these units mentioned that to me as well about the tantalum caps.
I will have to look into it.
Did you have a hard time finding replacement tantalum's of the same value?
Old 9th November 2018, 04:37 AM   #14
1audio is offline 1audio  United States
You can get electrolytics that are a suitable replacement. They are used as low ESR bypass filters around the sensitive parts of the circuits. These may be a suitable option https://www.mouser.com/datasheet/2/3...35-1095274.pdf The dipped tantalum caps are getting expensive and have a nasty habit of failing as a short.
Demian Martin
Product Design Services
Old 9th November 2018, 04:49 AM   #15
kevinkr's Avatar
<snip>
I had one actually catch on fire in my 3501A some years ago now, fortunately no real damage done, but if burned just like a candle.. They're just a bundle of mischief waiting to happen.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 10th November 2018, 04:43 AM   #16
No they're not terribly expensive or hard to find. I sourced all of mine from Mouser and I moved up from 25V to 35V rated Tants. I'm not sure if the voltage headroom will buy any more life out of them, but it certainly cannot hurt. My take on the tantalums is that the originals lasted 30+ years so I'll likely be gone from this world before the batch of new ones I installed begins to fail in my 3501.
KC
Old 11th November 2018, 01:36 AM   #17
KenwoodM2A's Avatar
Thanks!
I will replace mine and the electrolytic ones as well as soon as I'm done checking 3 more tuners. Hopefully I won't have any issues until I'm done !
Amber Distortion Meter ReadingsHide this!Advertise here!
Amber 3501A Distortion analyzer? audio king Equipment & Tools 17 30th August 2018 06:44 PM
VK-2 distortion meter vkaudiotest Equipment & Tools 0 27th October 2017 04:03 PM
JLH Distortion Meter in ETI SoundOff Everything Else 25 10th November 2016 02:25 PM
B & W Distortion Meter jdeitch11 Swap Meet 2 23rd February 2011 03:07 PM
Unmodified Radio Shack SPL Meter-Useful For Readings In Midrange And Bass? kelticwizard Multi-Way 7 4th August 2004 04:42 PM
