Equipment & Tools From test equipment to hand tools
aoYue 852
aoYue 852
Old 22nd September 2018, 07:16 PM   #1
kees52 is offline kees52  Netherlands
Default aoYue 852
I did buy a aoYue 852 however the air stream is to high and I blow the smd away.
I can not get it lower then 2.5 but it has to be get to 1 of 0.5.
I have look in it and try to find the fault, hoever it is equipped with a atmega 8 cpu and has triac regulators for the heat and the airpump, it uses pulswidth modulation.
This modulated output go into a npn buffer and then into a opto coupler who drives the triac, I do not see wel if this can be adjusted the right way, or need I to change the software or let the cpu working on a lower clock? she have use the internal atmega rc clock signal, lowering that do work then the air go lower also. I have try to make the resistor bigger on the opto coupler low voltage side, no effect, strange.
Someone tips or now what to do?. It does work quite good has no trouble to remove a chip.
Aoyue 852 Rework Station | eBay
thanks.
kees
Old 22nd September 2018, 08:31 PM   #2
PRR is offline PRR  United States
PRR's Avatar
Old 22nd September 2018, 09:00 PM   #3
Originally Posted by PRR View Post
I send this to the manufacturer. if it can not be cured I send it back in warrantie. But if it a easy fix then i do correct it myselfs.
aoYue 852Hide this!Advertise here!
AOYUE - Solder Station, Hot Air and Vac Pickup - $60 aterren Swap Meet 0 24th April 2018 10:01 PM
Hot Air Soldering Station AOYUE Int968A+ has desoldering vacuum? StylinLP Parts 4 11th March 2015 07:18 AM
Just bought Aoyue 936, now what solder to buy? everlong Equipment & Tools 16 21st June 2012 10:52 PM
