Welcome.
I've HP8903B Audio Analyzer. I would like control this instrument from my LabView 2010. I download drivers from NI : Keysight Technologies / Agilent Technologies hp8903b Analyzer - IEEE 488.2 (GPIB) Driver for LabVIEW - National Instruments . Instrument connect witch program, switches function on the front panel, measurement voltage etc. The problem is that it does not generate sine. Does anyone know how to solve this problem? DIP switches are set : 11100000 , when I turn on the SPCL 21.0 in generator (adres 28).
Hi Kamus,
Did you find a solution to the problem? If not you can follow this link HP 8903B in Float? another member had some issue which might be similar to yours and they did work through it. Kindly follow it and you can ask more on the thread to receive some guidance.
Thanks. I hope it helps.
