Equipment & Tools From test equipment to hand tools
Isolation Transformer, Variac and Dimmer Bulb Tester
Old 22nd August 2018, 12:20 PM   #21
anatech is offline anatech  Canada
anatech's Avatar
Hi John,
You control the current with the variac. Using a bulb anywhere introduces a variable and you really don't know what is going on with the capacitors.
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 22nd August 2018, 12:25 PM   #22
John Ess is offline John Ess
John Ess's Avatar
So it's a misconception that the variac just controls voltage and the bulb acts as a current limiting device?
Old 22nd August 2018, 12:28 PM   #23
anatech's Avatar
No, the resistance of the load works with the applied voltage to control the current. That way you get an accurate indication of the current drawn by the load.
-Chris
Old 22nd August 2018, 11:36 PM   #24
PRR is offline PRR  United States
PRR's Avatar
I believe the lamp will react faster than my hand on the knob.
Yes, low-volt and lamp introduce great uncertainty in what is going on; this is just for smoke-test.
Old 22nd August 2018, 11:39 PM   #25
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
yes, i use a 100 watt bulb, at 230 volts, when there is a fault in the equipment,
then that is just 43mA if current, further damage is averted and smoke is not let out...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 23rd August 2018, 04:11 AM   #26
PRR's Avatar
Originally Posted by TonyTecson View Post
...i use a 100 watt bulb, at 230 volts ... ...that is just 43mA if current....
434mA.
Old 23rd August 2018, 04:13 AM   #27
TonyTecson's Avatar
yes, i flunked math in school...
Old 23rd August 2018, 01:16 PM   #28
anatech's Avatar
I just watch the current meter. If it goes up rapidly you can stop before you reach 10 VAC or even lower.
-Chris
Isolation Transformer, Variac and Dimmer Bulb TesterHide this!Advertise here!
Dim Bulb Tester bloodtypw Instruments and Amps 30 26th October 2015 10:18 AM
Dimmer instead of variac? Doug Kim Parts 6 9th June 2008 04:37 PM
Variac Vs Bulb Limiter newb question Hiwatt25 Chip Amps 3 1st February 2008 08:25 AM
Looking for 230V >1KVA variac and 230V-230V mains isolation transformer offers Eva Swap Meet 1 28th July 2005 04:00 PM
