Equipment & Tools From test equipment to hand tools
DIY Voice Coil Winding Machine
Old 23rd March 2019, 08:57 AM   #21
ghemml is offline ghemml  Singapore
ghemml's Avatar
Hi Zampotech
The encoder which you mentioned is called Closed Loop controller in industrial terms.
I have a pair of Closed Loop Hybrid Stepper motor, Nema 2 size. Integrated contoller fron Aliexpress. 2.0Nm torque shold it should be enough to handle at least 18awg wires.
And probably will be upgrading to Arduino Due as it has a 84mhz compared to my current 16mhz Mega.
Arduino Due PWM reaches 8mhz, maybe more than enough for the Closed Loop Hybrid Motor.
800 microstep for the hybrid motor and with Arduino Die, i should be able to reach 600rpm or 10rps.
Currently this machine can achieve is 150rpm using DRV8825, which is bloody noisy.
You should try Arduino, it is very user friendly Microcontroller.
Old 23rd March 2019, 08:59 AM   #22
ghemml's Avatar
And also my part list for those who are interested
Proximity Sensor Switch Inductive Switches
M12 4mm DC 5V NPN NO LJ12A3 4 Z/BX 5V Inductive Proximity Sensor Switch Inductive Switches-in Switches from Lights & Lighting on Aliexpress.com | Alibaba Group
ER25 or ER32 collet Motor shaft Chuck - 12mm bore
ER20 collet Motor shaft Chuck ER ER11 ER16 ER25 ER32 spindle Extension Rod tool holder CNC Milling drill chuck B10 12 18 JT2 6-in Milling Cutter from Tools on Aliexpress.com | Alibaba Group
M8 60mm Clamping Lever
M8 16mm to 60mm Clamping Lever Machinery Adjustable Handle Locking External Male Thread Knob Hex Screws Tools Accessory-in Screws from Home Improvement on Aliexpress.com | Alibaba Group
SFU1204 400mm rolled ball screw
SFU1204 200 250 300 350 400 450 500 550 600mm rolled ball screw C7 with 1204 flange single ball nut BK/BF10 end machined CNC -in Linear Guides from Home Improvement on Aliexpress.com | Alibaba Group
New linear guide rail HGR20CC
New linear guide rail HGR20 400mm long with 1pc linear block carriage HGH20CA HGH20 HGW20CC CNC parts-in Linear Guides from Home Improvement on Aliexpress.com | Alibaba Group
10-20pcs/lot M5*L(10-35) +8 stainless steel 304 hex socket spacer standoffs - 25mm
https://www.aliexpress.com/item/10-2...27424c4dBGFWZZ
SCS10UU Linear Ball Bearing Block
https://www.aliexpress.com/item/4pcs...AbTest=ae803_3
Old 23rd March 2019, 09:48 AM   #23
Zampotech is offline Zampotech  Russian Federation
Hi Ghemml
I used simple solutions so that the work on my winding machine did not require additional knowledge. The employee is required to know the diameter of the wire, the number of turns, set the width of the winding and press the START button.
The company, which was sold to my winding machine for working women. He doesn't know ARDUINO Women have other values
The second point that was important to me. This price. The enterprise-customer wanted to receive about 20 winding machines at the price of only $250/pcs.
To accelerate winding they began to use not one universal machine, and several, for each winding separately.
Old 23rd March 2019, 10:40 AM   #24
ghemml's Avatar
I see.
For my design also, there is no need to know arduino or programming. Maybe know how to upload the sketch to an arduino and basic wiring.
All the visual basic and arduino code are for DIYer who wants to customize it.
Otherwise, my share drive contains the executable .exe file for Graphical User Interface. And the arduino code probably just flash into the board.
I also uploaded all the AutoCAD files for the parts fabrication.
Old 23rd March 2019, 10:51 AM   #25
Originally Posted by ghemml View Post
For my design, i don't think there is need to know arduino or programming. Maybe know how to upload the sketch to an arduino and basic wiring.
All the visual and arduino code are for DIYer who wants to customize it.
Yes, I understand. I can do the job on your winding machine. And all users this forum, too,will be able work on your winding machine. Your winding machine is certainly perfectly executed. You have a very high professional level of performance.
I was given the condition that my winding machine could work the most stupid worker.
Of course, it is inferior in function to your winding machine. Software control allows you to change the operating modes more widely. In my winding machine, hard logic.
Old 23rd March 2019, 11:02 AM   #26
ghemml's Avatar
I have a habit of pushing my design to the limit. Therefore for this CNC winding machine i am very concerned about backlash, noise, vibration and heat on the motor controller
For performance i wish to achieve from the current speed of 150rpm to 600rpm. One reason why i bought the closed loop hybrid stepper motor.
For the linear shaft ball slide, i wanted to upgrade it to linear rail slide. To make it super rigid.
Antiback lash for the ball screw to achieve 10 micron accuracy.
And finally the User Interface logic, which i still trying to understand fully how a user point of view will want to see and have on their graphical interface.
Old 23rd March 2019, 11:07 AM   #27
In my opinion, there is no need to achieve universality. For practical work you need to have two winding machines. One for thin wire, the second for thick wire.
Backlash in 10-100 microns does not affect the quality of the winding. The wire finds its place in the winding by itself
The interface should probably consist of two parts. The first part have only two digits, the number of turns and the diameter of the wire, and the name of the winding. Perhaps even the width of the winding. The second part can have a group of settings, such as winding speed, speed dial profile, winding type, winding step.
Each mode must be given its own name to transfer this mode to the winding machine.
Old 23rd March 2019, 11:22 AM   #28
ghemml's Avatar
The backlash did has some effects on very thin wire and while doing many multiple layers with big winding width, which i tested.
I try to make it industrial grade by reaching up to 0.01mm thick winding.
Old 23rd March 2019, 11:28 AM   #29
For ultra-thin wires definitely need to remove the backlash. For wire of 0.12 mm is enough to take a step slightly larger than the diameter of the wire.
Old 23rd March 2019, 11:28 AM   #30
ghemml's Avatar
Its just a personal challenge to perfect it.
DIY Voice Coil Winding MachineHide this!Advertise here!
winding a voice coil Magnasanti Planars & Exotics 22 28th April 2019 04:17 AM
Voice Coil Winding Questions JTNorman Multi-Way 3 24th October 2017 01:38 PM
Voice coil custom winding? jvhb Parts 9 29th January 2017 01:20 PM
Voice Coil Winding and Length fidelia91 Multi-Way 11 21st July 2015 04:28 PM
Going to try winding a voice coil johnthedoctor Parts 15 1st September 2006 12:03 PM
Copyright ©1999-2019 diyAudio
