Equipment & Tools From test equipment to hand tools
DiAna, a software Distortion Analyzer
Old 24th November 2019, 07:51 PM   #941
phofman is offline phofman  Czech Republic
Thanks for the correction, sorry for the misinformation.
That MCU would not sample like an audio ADC, no need for the purpose. Precise value is already sampled by the soundcard. If an approximate value were needed on the PC side, outside of the analyzer, a few samples a second behind some AC/DC to hold peaks (somehow already present in the device for the existing MCU) should be easily attainable.
But again, the ADC is not point of this. I just wanted to suggest one way towards enhancing existing devices with simple remote interface without complicated modifying their firmware, if possible.
Old 24th November 2019, 08:39 PM   #942
thumb is offline thumb  Europe
I like your approach @phofman
Old 25th November 2019, 05:18 AM   #943
mkc is offline mkc  Denmark
Sorry for continuing being off-topic in Edmonds thread.
However, I would like to point out that instead of using the ATMega processor based boards a STM32 based board would be a better solution. STM32F103 based boards are also dirt cheap on Aliexpress. The board often referred to as the Blue-pill board would be a candidate and are also supported by the Arduino framework. So it shouldn't be that different from a programming point of view.
Although not as cheap there also is this board from ST's Nucleo series. It has an STM32L432 which also has USB connectivity, but also hardware floating point module if needed. NUCLEO-L432KC STMicroelectronics | Mouser Europe
Back to normal again.
Mogens
Old 10th December 2019, 12:35 AM   #944
dimitri is offline dimitri  United States
dimitri's Avatar
Hi Edmond,
Can you please mention (here or on your web site) soundcards that have been successfully used with DiAna?
Thank you
Old 10th December 2019, 03:15 AM   #945
1audio is offline 1audio  United States
used the following:
ESI Juli@
EMU 1212, 1616
Lynx L22
RME HDSP9632
RTX
QA401
Pretty much anything that can support an ASIO interface properly. Some of the above were harder to get working but that's typical with the DAW software as well.
Demian Martin
Product Design Services
Old 10th December 2019, 07:42 AM   #946
Also EMU 0202 / 0404 / Tracker works with Diana in Win/Linux
Old 10th December 2019, 08:16 AM   #947
DNi is online now DNi  Switzerland
Adding Motu Audio Express to the list, with the Motu ASIO driver.
Old 10th December 2019, 10:51 AM   #948
Edmond Stuart is offline Edmond Stuart  Netherlands
Edmond Stuart's Avatar
In addition to above list:
ESI 192X
Roland Quad Capture
Roland Octa Capture
Xonar Essence STX
Cheers, E.
http://www.data-odyssey.nl/
Old 10th December 2019, 11:08 AM   #949
BSST is offline BSST  United States
BSST's Avatar
Would the EMU 0404 USB also be in this list?
Thanks!
Old 10th December 2019, 12:15 PM   #950
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Thanks!
post 946 ...
DiAna, a software Distortion AnalyzerHide this!Advertise here!
Analyzer Software Overview dennis h Equipment & Tools 153 10th December 2017 07:40 AM
Distortion analyzer troystg Equipment & Tools 5 7th December 2016 06:11 AM
True RTA analyzer software JAY X Equipment & Tools 5 18th October 2016 01:29 PM
Spectrum Analyzer software recommendations head_unit PC Based 8 22nd January 2012 06:39 AM
HP8903B Audio Analyzer Software Conrad Hoffman Equipment & Tools 11 1st June 2010 01:21 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
