Equipment & Tools From test equipment to hand tools
DiAna, a software Distortion Analyzer
Old 23rd March 2018, 03:53 AM   #441
1audio is offline 1audio  United States
The problem in deleting the old .ini file is saving the cal constants. I just use a screen snip to save them but they should be recorded. Maybe the ideal would be a simple spreadsheet to calculate the correction based on measured output from a known source.
Demian Martin
Product Design Services
Old 23rd March 2018, 04:17 AM   #442
The new version loaded and came right up. Works without issues. System is aware and I added a link by pinning the icon to the task bar.
Can you explain the numbers next to the marker/cursor? Frequency I get frequency but the other two numbers I don't.
What is the phase relationship between the reconstructed residual waveform and the fundamental Especially higher harmonics. it can be really useful to determine what part of the cycle is distressed to know where to look.
Demian Martin
Old 23rd March 2018, 11:40 AM   #443
Edmond Stuart is offline Edmond Stuart  Netherlands
Edmond Stuart's Avatar
Default Configuration files
Hi Demian,
An old ini file is only deleted when it is heavily corrupted, i.e. when a parameter is missing for example. If a parameter is manually altered, a CRC error is reported, which can be overruled by pressing the "Proceed" button and the cal. constants will be preserved. However, if the "Use defaults" button is clicked, the cal. constants will be replaced by 1, of course. In the latter two cases, the old ini file is not deleted (only possibly altered).
> "simple spreadsheet": Oh No! On your request, I've just made provisions to save the ini file under a different name, see post 421. The the cal. constants can be found under: ADC1Calib=1, ADC2Calib=1, DAC1Calib=1 and DAC2Calib=1. In this case default values are shown. Note: These configuration files will never be deleted by DiAna.
Cheers, E.
http://www.data-odyssey.nl/
Old 23rd March 2018, 01:40 PM   #444
Default Phase relationship
Hi Demian,
Good to hear.
I assume you mean the numbers at the bottom of the marker next to x: and i:
These are the abscissa of the screen and the index to the FHT array. In the past, I used them for debugging. They can be deleted by now. So just ignore these numbers.
The phase relationship is undistorted, or at least, it should be. Basically, the residual waveform is not a reconstruction, as it is obtained by subtracting an ideal sine from the input signal directly. So the phase error should be zero. But in a sense, a reconstruction takes place when the residual is filtered, which is done by means of an FHT, followed by an inverse FHT. Filter characteristics can be specified in the Distortion menu under LP Filter (Hz), Gaussian filter and Brick-wall filter.
Sure! And that was one of the main reasons to start this project anyhow.
Cross-over distortion, for example, is easily detected by means of the residual, see simulated picture below (which also shows a correct phase relationship).
BTW, are SNR figures better now?
Cheers, E.
PS: The phase of the 3rd harmonic is -179.98 degrees, so almost correct.
Old 23rd March 2018, 04:22 PM   #445
lemon is offline lemon  Greece
Hi Edmond,
Just I download the new 1.48.9 version.
I see a new calibration or it is something else?
The V is Vp still or Vrms?
What is relation of "dB"?
Old 23rd March 2018, 05:04 PM   #446
Default Calibration factor
Originally Posted by lemon View Post
Hi Edmond,
Hi Manolis,
At the moment, it's still Vp and the relation is simply dB = 20*log10(Vp).
The only new thing is that you also can enter the cal. factor in dB.
In the next version however, these values will be interpreted as RMS and, to avoid confusion, you will see "Vrms" respectively "dBV" in the menu.
How about your PC and OS? Is it fast enough?
Cheers, E.
Old 23rd March 2018, 07:32 PM   #447
OK, thanks for the info.
My lab PC?
Oh! it is a funny long-long story.
Never mind, there is no any medicine for this, I couldn't find an alternative driver for the graphics!
With this microsoft-Intel driver there is no happy!
Old 24th March 2018, 02:28 PM   #448
Hi Demian,
In the next version, I will revert back to the procedure from earlier versions. So instead of deleting the old ini file, it will be renamed with a .bak extension.
Cheers, E.
Old 24th March 2018, 02:33 PM   #449
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Originally Posted by Edmond Stuart View Post
Hi Demian,
Cheers, E.
Edmond, is it not possible to xor the various entities in the two .ini files to keep the good old ones?
I realize I may know just enough about this to be dangerous ;-)
Jan
Old 24th March 2018, 03:22 PM   #450
PS: Above procedure only applies to the regular ini file, thus not configuration files that are saved under different names (by using Save configuration in the file menu). These files are first deleted and replace by a fresh one. The reason why they are not simply overwritten is because possible old rubbish will not be removed.
Cheers, E.
DiAna, a software Distortion AnalyzerHide this!Advertise here!
Analyzer Software Overview dennis h Equipment & Tools 153 10th December 2017 08:40 AM
Distortion analyzer troystg Equipment & Tools 5 7th December 2016 07:11 AM
True RTA analyzer software JAY X Equipment & Tools 5 18th October 2016 02:29 PM
Spectrum Analyzer software recommendations head_unit PC Based 8 22nd January 2012 07:39 AM
HP8903B Audio Analyzer Software Conrad Hoffman Equipment & Tools 11 1st June 2010 02:21 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
