USB Audio interface for measurement
Well I ordered the M2 from B&H Photo, they have the m4 and m2 in stock but dont know how many.
$169 delivered.
I read the manual and noticed the trs on output needs an open circuit on ring 1/4" line out.
So to do a loopback have to make a cable. No problemo.
It includes the USB-C to USB3 cable adapter.
Actually I need the MIDI but will go back and order the M4 if all works out.
May as well try out REW at same time. I like the presentation plots as opposed to screen captures currently using.
I'm looking to measure amplifiers. Does anyone know what the actual bandwidth of these things are? MOTU quotes "20kHz" on their datasheet, but is this just regurgitated "industry standard" information or is it because of a band-pass filter?
Also, it'd be nice to know if they meet their (impressive looking) distortion specs. I was planning to use a notch filter to filter out the fundamental and try to measure lower distortion numbers, but that can only work if the bandwidth isn't a trainwreck.
Right now it's between the MOTU, a used Lynx card (L22) or option 3.
Option 3 entails finding the schematics for the Cirrus Logic CS5381 evaluation module and designing my own PCB for less than what that EVM costs. I would then use an off-the-shelf interface (I believe minidsp has one) to go from I2S to USB (so I don't have to write my own drivers). This is obviously the most work and not something I want to deal with, but I'll do it if it's the best option.
If I can teach myself how to solder them, the AKM 5572 has really great specs in a QFN package.
The AP portable series and the ATS-1 has a residual THD+N of -92dB. It'd be nice to do a little better than that, really nice to get better than -100dB. This should be doable.
There is a fourth option, hack the motu. Ie add BNCs , bypass front end and other hee haww .
M4 line-in appears to do that. Probably has esd protect etc that can be removed.
Motu quotes -106 thd+n I'm thinking is measured.
Mine here in a few days so ill put loopback up here.
The -106 THD+N is what intrigues me. That's very impressive- better than some AP boxes. The amazon reviews (which are generally useless) do seem to suggest that the noise floor is "invisible", so there might be something to this.
Edit: Anyone know if the L22 works with Windows 10?
2nd harmonic at 20 kHz is 40 kHz. I like to know what my designs are doing up at 20 kHz. Now whether the MOTU has the same bandwidth limiting the Behringer has, that's the real question.
The Lynx definitely can do 90 kHz, so if the MOTU can't I'll go that route.
Ok I see, but this is interesting.
Say for example Mary can hear fine 19-21 khz.
She will not hear the harmonics though?
I'm not going to argue yes or no to this, however I firmly believe that if one wants to design a really good amplifier, it's important to look at what it is doing throughout the whole spectrum. Just because you can't hear it doesn't mean it shouldn't be addressed in a design.
