Equipment & Tools From test equipment to hand tools
Autoranger for soundcards
Old 3rd August 2019, 07:37 PM   #461
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
First batch is shipped.
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 3rd August 2019, 09:49 PM   #462
astromo is offline astromo  Australia
Jan
Fantastic!
Old 7th August 2019, 11:15 AM   #463
jan.didden's Avatar
Default 20k Rin variant
Update 7 August 2019 - new 20k Rin variant!
Some of you who work mainly with tube equipment have asked for a version with a higher input impedance than the 10k for the stock MK II. Input impedance is a compromise between complexity of the attenuator and the frequency response as was the case with the 100k Rin of the initial version. That 100k required quite a complex calibration for flat frequency response.
The 10k MK II in contrast doesn't need any calibration and is flat to over 1MHz. But listening to you, I build up a unit with 20k input impedance, and tested it. I am happy to report that it has a flat frequency response out to over 600kHz in all settings, without any calibration.
The 20k input impedance version requires some different values for the attenuator resistors. To my surprise, it all fell so nicely together with existing E96 values that 8 less resistors are required, 2 positions on the board have to be shorted and 6 can be left open! Here is the BOM fragment for the 20K Rin variant. All other part values and designations remain the same.
Worst-case attenuation error is 0.1dB in any setting; Rin variation is 19.95k to 20.08k (calculated).
Linear Audio AR MK II Attenuation board Bill Of Materials variant for 20k Rin version only!
Jan
Old 13th August 2019, 08:41 PM   #464
Package received.
Thanks Jan.
Now I just have to warm up the soldering iron.
Old 13th August 2019, 10:56 PM   #465
Originally Posted by astromo View Post
Package received.
Thanks Jan.
Jan - query regarding R48/R49 for the Attenuation PCB BoM. What's the required tolerance? You haven't nominated a recommended part, just a comment and a resistance value.
From looking at the board these resistor should just be straight forward through hole axial resistors, shouldn't they? Why make the comment, 0.4" pitch?
EDIT: Also, what's your take on "low" for temperature coefficient?
Old 14th August 2019, 12:37 AM   #466
Answer to self - board hole spacing. Broke out a ruler and put it up against the board. Came up with 10 mm, which is close enough to 0.4". Got confused by the octopart BoM search function. The have a filter for "terminal pitch" which relates to SMD parts and the rest.
Old 14th August 2019, 06:03 AM   #467
jan.didden's Avatar
Yes. These are run-of-the-mil resistors for biasing zenerdiodes. If they fit, they are OK, hence the 0.4in pitch ;-)
Same for R29 and R31.
Jan
Old 14th August 2019, 10:01 AM   #468
Jan
No worries.
I've defaulted to +/-1% tolerance and 100ppm/C, 'ish.
Autoranger for soundcardsHide this!Advertise here!
Using 2 soundcards merlinx76 PC Based 1 1st April 2011 07:46 PM
Best audiophile Soundcards ostripper Digital Source 3 18th August 2008 02:51 PM
soundcards exurbia Digital Source 10 13th August 2008 05:06 AM
Soundcards JoeBob Digital Source 21 22nd January 2002 07:16 AM
Copyright ©1999-2019 diyAudio
