Good luck mate.they want to refund me $50 dollars so now im going to have to pull the covers off and make sure no components were damaged.. there tends to be a lot of things right near the cover and they all weave together intricately so heres hoping theres no REAL damage.
If you need help, you might hop over to eevblog forums as there are MANY people very knowledgeable about Tek stuff there.
Sent from my LG-ls990 using Tapatalk
thanks pedro - at least that way if there is something broken and i cant get a full refund i may be able to fix the unit.
Yep, hopefully it isn't but if it is, they can likely help. The biggest thing I would be worried about actually is the plates inside of the CRT. If those get broken off you have to order a new CRT and the CRTs are not always easy to find.
