Equipment & Tools From test equipment to hand tools
USB sound card for audio spectrum analysis
Thread Tools
Old 24th April 2016, 05:03 PM   #181
diyAudio Moderator Emeritus
SY's Avatar
Hp, did you measure third harmonic of the 10k? Thanks.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 24th April 2016, 06:41 PM   #182
HpW is offline HpW
Well, you may know, may you read on the later "Low-distortion Audio-range Oscillator"... topic..
The real THD of the LDO is usual lower as the LNA &ADC shows up! This means, a direct measurement, as FFT does, will show you a Brut Force measurement with the underlying LNA & ADC performance! Also will show you the phase noise around the fundamental signal.
In other words, the THD3 or THDxx may show -120dB and really is may on -140dB. To get into this real THD, a additional filtering of the Har1 is needed / required. Look at the later Samuel Groner's "Low-distortion Audio-range Oscillator" measurement.
Hp
FFT Analyzer & Generator at www.hpw-works.com
Old 25th April 2016, 02:02 AM   #183
vicnic is offline vicnic  Latvia
Originally Posted by HpW View Post
Here some measurements using your lovely LDO's...
And it will always be the hard part with the input LNA & best ADC. And finally for a DIY, to effort such HW/SW or even to build with the existing knowledge such HW.
Hp
Thank you
Old 25th April 2016, 06:41 AM   #185
mkc is offline mkc  Denmark
Hi Victor,
Thank you. You have removed the potentiometer from the left channel also. Have you done this to make fixed gain?
Mogens
Old 25th April 2016, 11:41 AM   #186
Originally Posted by mkc View Post
Hi Victor,
Mogens
Yes, potentiometers was also removed. Previously, I done similar job for both channels, but later, when I can't get good results from the left channel, I blocked it. Gain is fixed. I already have the external divider for the level changes.
Victor.
Old 25th April 2016, 11:56 PM   #187
One correction of mistake. R28 new value is 6.8k. It is not very significant, but has an effect on the gain.
http://content4-foto.inbox.lv/albums.../0202schCc.jpg
Victor.
Old 16th March 2017, 05:15 AM   #188
tjstyle is offline tjstyle  Indonesia
Impressive, below -130db.
are you use your your low noise 1khz oscillator for feeding the signal to E-MU0202?
Originally Posted by vicnic View Post
Wish to tell you little about one amazing result with the E-MU 0202. Not far ago got this card from the ebay auction for . I was planning this for my laptop as spectrum measurement tool. This USB sound card uses AK5385 as ADC. The chip is semi compatible with the AK5394, and I thought, that maybe I can replace the ADC chip, if it needed, but seems that is not needed. After one working day, some changes in the buffer amp and little tricks I got wonderful results from the right channel of the ADC. The left channel was more worse (seems that the chip internal problems), and I blocked it. As result I got this relatively small "magic" box, and the nice spectrum picture:
http://content32-foto.inbox.lv/album...02/0202out.jpg
http://content32-foto.inbox.lv/album...2/1kHz0202.jpg
http://content32-foto.inbox.lv/album...02/0202ins.jpg
Victor.
Old 30th March 2017, 10:12 AM   #189
stajo is offline stajo  Sweden
Indeed an impressive result with the EMU0202USB. Has anybody tried the 0404USB?
I am your father
Old 30th March 2017, 11:23 AM   #190
soongsc is offline soongsc  Taiwan
soongsc's Avatar
I just started playing around with the Babyface Pro, seems quite impressive for a device this size.
Sent from my iPhone using Tapatalk
Hear the real thing!
USB sound card for audio spectrum analysisHide this!Advertise here!
Thread Tools
USB vs PCIe Sound Card for audio analysis TheGimp Equipment & Tools 207 6th August 2016 01:14 PM
usb sound card for 2.1 audio aussiebuddha Digital Source 3 15th June 2011 10:12 AM
how to make a 4 channel USB to Audio sound card/dac Joseph R Digital Line Level 8 4th December 2010 06:19 AM
FS or trade: M-Audio MobilePre USB sound card (big pictures) Glowbug Swap Meet 2 1st September 2009 09:05 PM
USB audio sound card (PCM2702) veteran Swap Meet 14 30th November 2006 05:39 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
