Equipment & Tools From test equipment to hand tools
DIY Audio Analyzer with AK5397/AK5394A and AK4490
Thread Tools
Old 6th January 2019, 10:45 AM   #2541
HpW is offline HpW
Originally Posted by etlasr View Post
If I have got the hang of how to upload attachments this should show 3 pics of the mains XFR as factory fitted,vertically up against back panel and hanging outside of side panel. Significant differences.
Interesting would also the channel cross talk (1kHz / 20 kHz) if one input is opened or shorted While using only ONE DAC
Hp
FFT Analyzer & Generator at www.hpw-works.com
Old 7th January 2019, 01:06 PM   #2542
zfe is offline zfe
Originally Posted by Pinebox Studio Servi View Post
Anyone running this on Mac and if so what program are you using?
Many Window's programs, as e.g. Arta and Audiotester, run on Mac using wine. Only changing the sampling rates in the programs does not work properly. You have to do that (additionally) manually using Audio-Midi-Setup (in my older OS X this is in the utilities folder).
Old 7th January 2019, 01:32 PM   #2543
mbrennwa is online now mbrennwa  Switzerland
mbrennwa's Avatar
MATAA. It has level calibration with automagic reading of the RTX level controls implemented.
Old 17th January 2019, 01:25 PM   #2544
SSassen is offline SSassen  Netherlands
SSassen's Avatar
Apologies if this has been covered already, but I'm pressed for time and not in a position to read all +200 pages of this topic.
I have two quick questions for the experienced RTX6001 users. Mine was one from the 1st batch, and came with parts I need to install, but I can't find instructions on the RTX website?
Also, I tried updating the firmware after having installed the latest and greatest drivers/software from the RTX website, but it won't let me perform the update as the application comes back with an error message because it can't find TUSBAudioDfu.exe?
Any suggestions you fine gentlemen can provide for the above would be appreciated! Thanks!
Mediocre is not my middle name.
Old 17th January 2019, 02:08 PM   #2545
JensH is offline JensH  Denmark
Please read the "Hardware modifications" section at the bottom of the first post.
Unpack the files from the downloaded zip file.
The TUSBAudioDfu.exe and the TUSBAudioDfu.xml files should be placed together in a folder. Run the TUSBAudioDfu.exe application from that folder. Once the application has started, locate the RTX6001_i2o2_V0119.bin file where you placed it after download, press Open and Start. That should work.
Old 17th January 2019, 02:16 PM   #2546
SSassen's Avatar
All set! Thanks Jens, much appreciated! Now where did I put my 8R dummyload?
Old 15th February 2019, 08:43 PM   #2547
SSassen's Avatar
I can’t seem to grow accustomed to using the RTX6001 for the simple reason of not being able to find software that’s not cumbersome to set up and use. I am a long time Analog Discovery with Audio Analyzer suite package user and I absolutely love it for its ease of use and simplicity, it is what I use on a day to day basis for quick analysis and measurements.
Is a similar software suite available for the RTX6001? I don’t mind spending a bit of money on software that allows me to operate my RTX6001 in similar fashion as I’m familiar with with the Analog Discovery.
Any suggestions would be appreciated, thanks!
Old 16th February 2019, 06:49 AM   #2548
mbrennwa's Avatar
Originally Posted by SSassen View Post
I can’t seem to grow accustomed to using the RTX6001 for the simple reason of not being able to find software that’s not cumbersome to set up and use. ... Is a similar software suite available for the RTX6001? ... Any suggestions would be appreciated, thanks!
I have not heard of the Analog software, so it's difficult to tell what you're after. What kind of measurements are you looking for ("oscilloscope", electronic, acoustic, etc.)? What functionality and features do you need? What computer operating system do you use?
That said I don't think this thread is the right place to ask this question because most audio analysis software tools are designed to work with just about any USB audio interface. Since the RTX 6001 is just yet another USB audio interface from the software perspective, your question is not specific to the RTX 6001.
Old 17th February 2019, 09:46 PM   #2549
agdr is offline agdr  United States
agdr's Avatar
I'm of the school that says careful design of magnetics and their locations is very important (I have designed high power magnetics in aerospace SMPSs) but the best and cheapest / free way to get significant improvements is distance.
Ah I'm just now getting caught up on the thread and this issue! So true, distance solves a great many things.
An external transformer really would be the ultimate solution. I would also be quite interested in buying any shielded transformer Jens finds that would help.
Old 18th February 2019, 10:14 AM   #2550
SSassen's Avatar
I want to be able to simply generate graphs as per the attached image, without having to spend an hour clicking in different menus to set this up. In that regard the Audio Analyzer suite for the Analog Discovery 2 is a godsend!
File Type: jpg ecc83_bootstrapping_028_high_mu_ecc83_1w_8r.jpg (365.1 KB, 292 views)
DIY Audio Analyzer with AK5397/AK5394A and AK4490Hide this!Advertise here!
Thread Tools
New AKM Stereo ADC AK5397 announced JensH Digital Source 20 24th December 2014 12:05 PM
New AKM Stereo ADC AK5397 ??? HpW Equipment & Tools 6 16th May 2014 04:26 PM
NTi Audio XL2 Handheld Audio Analyzer Fredenando Equipment & Tools 0 18th April 2010 03:04 AM
AKM AK5394a TobWen Digital Source 41 31st December 2003 06:18 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
