Equipment & Tools From test equipment to hand tools
DIY Audio Analyzer with AK5397/AK5394A and AK4490
Thread Tools
Old 14th March 2018, 05:09 PM   #2041
JensH is offline JensH  Denmark
To get the typical -124dB @1kHz @0dBV you should set the output signal to -20dBFS, the output attenuator at 20dBV and the input at 10dBV.
Use a low sample rate (44.1 or 48 kHz) and use one channel only.
There is no way to shut off one analyzer channel completely. Just unplug the input cable and leave the inputs open. Or short the unused input to pin 1 of the XLR.
Old 16th March 2018, 07:32 PM   #2042
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
Just wanted to let you know that the RTX works well with a measurement microphone. No microphone preamp needed with the 100 mV input. All you need is to provide the phantom voltage to the microphone. I used a Behringer Micropower PS400 to achieve that. Easy!
Old 22nd March 2018, 06:09 PM   #2043
OK, time to address a couple of the issues that have been raised over the last couple of months.
Instability with certain source impedances (inductive).
I have looked at the cause and possible solutions. After a lot of simulations and measurements I ended up with a solution that is simple to implement and doesn’t have any significant impact on the performance.
The solution involves adding a series combination of a 22 pF capacitor and a 1.5 kohm resistor from each input line to ground. So 4 of these are needed. They can be added internally on the PCB or they can be added in the XLR connector of the input cable.
Shields.
As mentioned here I have designed a shield for the input amplifiers of the RTX6001.
The shields are back from manufacturing and they are ready for shipping.
We have put together an upgrade kit, consisting of 5 x 22pF/200V NP0 capacitors, 5 x 1.5kohm resistors, 2 x wires and 2 x shields. Why 5 x capacitors and resistors when only 4 are needed? To have one spare in case something goes wrong
I expect that the upgrade kits will be sent to all customers this week. And they are free of charge.
RTX does not offer to mount the upgrade kits in this case.
Please see the attached documents for information on how to install the shields and mount the components.
Jens
File Type: pdf RTX6001 V1 Input Stability modification_180315.pdf (142.1 KB, 308 views)
Old 22nd March 2018, 06:23 PM   #2044
Microfast is offline Microfast  Italy
Nice, thanks for your effort !!!
Old 22nd March 2018, 06:37 PM   #2045
mbrennwa's Avatar
Wow!
Old 22nd March 2018, 06:47 PM   #2046
anatech is offline anatech  Canada
anatech's Avatar
Hi Jens,
That is outstanding customer service! Many thanks for your continuing efforts to improve your instrument.
As it turns out, I use it every day. Normally not to the extremes of it's capabilities, but the extra information it shows can be invaluable.
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 22nd March 2018, 06:50 PM   #2047
Ghianni is offline Ghianni  Greece
That's Great!
Old 22nd March 2018, 06:56 PM   #2048
jcga is offline jcga  France
Hi Jens,
Impressed I am !
I'm really happy to have been on the group by...
All the best from France
Old 22nd March 2018, 07:24 PM   #2049
lemon is offline lemon  Greece
You are the best, excellent customer service!
Old 22nd March 2018, 07:56 PM   #2050
nyt is offline nyt
Great news
DIY Audio Analyzer with AK5397/AK5394A and AK4490Hide this!Advertise here!
Thread Tools
New AKM Stereo ADC AK5397 announced JensH Digital Source 20 24th December 2014 01:05 PM
New AKM Stereo ADC AK5397 ??? HpW Equipment & Tools 6 16th May 2014 05:26 PM
NTi Audio XL2 Handheld Audio Analyzer Fredenando Equipment & Tools 0 18th April 2010 04:04 AM
AKM AK5394a TobWen Digital Source 41 31st December 2003 07:18 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
