Equipment & Tools From test equipment to hand tools
help using Tube Tester
Old 30th January 2004, 11:05 AM   #1
ebarker2 is offline ebarker2  United Kingdom
Default help using Tube Tester
Ive been loaned a US Army (surplus) Signal Corps Tube Tester 1-177-B made by Tripplet Electric and a Tube Socket Adaptor Kit MX/949A/U. Unfortunately the lendor cant find the instruction manual at the moment.
My power amp has gone, and Id like to test my Sovtek KT88s. Does anyone know of a simple method of doing this using this machine. Its 120 volts and I will have to use a transformer, being in the UK.
Old 30th January 2004, 03:21 PM   #2
DaveInVA is offline DaveInVA
You can download the manual here:
I-177B Data
Dave
Old 30th January 2004, 04:02 PM   #3
Default 220 vt transformer
thanks Dave,
Do you think a 1650watt transformer is enough?
best
edward
Old 31st January 2004, 03:30 AM   #4
I doubt a I-177b draws even a forth of that so it should be fine..I wouldnt be surprised if the I-177b has 220 taps on its mains transformer but I wouldnt swear to that
Dave
help using Tube TesterHide this!Advertise here!
Tube Tester's Space1 Equipment & Tools 17 2nd June 2009 09:54 PM
DIY My tube tester sjh327 Equipment & Tools 0 30th November 2008 03:25 PM
Tube Tester jtwrace Equipment & Tools 5 8th September 2007 05:47 PM
Tube tester Sjef Equipment & Tools 6 29th January 2007 09:38 PM
tube tester TJ Equipment & Tools 11 5th April 2005 03:23 PM
Copyright ©1999-2019 diyAudio
