Equipment & Tools From test equipment to hand tools
DIY programmable dual channel bench PSU 0-50V/3A
Old 28th January 2015, 06:25 AM   #11
prasimix is offline prasimix  Croatia
prasimix's Avatar
Thanks for your input. I'll possibly take another route using thiner Alu plate (1.5-2mm) make all holes by myself and find some cheaper laser engraving or color transfer method for labels.
Of course any new idea is welcomed.
Old 28th January 2015, 08:27 AM   #12
quadtech is offline quadtech  India
wow - nice project. There are some cool diy ideas for front panels.
A couple -
Professional looking front panels
FRONT PANEL DESIGN AND CONSTRUCTION IN SYNTHESIZER PROJECTS
Old 28th January 2015, 09:59 AM   #13
prasimix's Avatar
Excellent recommendations! I like this Lazertran solution (Method 3 from FRONT PANEL CONSTRUCTION IN SYNTHESIZER PROJECTS), but also polypropylene (PP) folder approach (described in Professional looking front panels) has a great feature to make "windows" which can make LED's position very attractive. Many thanks!
Old 28th January 2015, 12:17 PM   #14
TheShaman is offline TheShaman  Europe
The following approach was recommended by a forum member in another thread:
https://www.youtube.com/watch?v=Yj0Bv4UEFSs
I think you'll find it interesting.
"You have a hierarchy: a mathematician, a physicist (which is a failed mathematician), and an engineer (which is a failed physicist)." - Andrew Jones
Old 28th January 2015, 04:01 PM   #15
prasimix's Avatar
Fantastic idea! Huh, how many hours I spent working on PCB layout without idea that it can be used for other important part of the project
Old 28th January 2015, 06:22 PM   #16
Frex is offline Frex  France
I agree with you prasimix, I ask me why i don't have think about that before !
As of you, i will seriously look this solution for my own psu project.
And also very good work for your project ! :-)
Frex
Old 5th February 2015, 09:53 PM   #17
prasimix's Avatar
Smile PCBs is arrived...
PCB's arrived yesterday or within 2 weeks from moment of ordering. A nice supplier (printed.cz) which I'd like to recommend (thanks permaneder).
Here is the main board where is located all circuit from Sheet 1 to 4 namely input bridge rectifier and capacitors, power pre-regulator, power post-regulator (CV and CC), bias supply pre-regulator and LDOs, OCP, CC/CV indicators and isolated sync for pre-regulators. That is a functional analog part of the PSU. On the same board is also located digital part that is used to communicate with MCU board via SPI. That mean DAC, ADC and I/O expander.
Old 5th February 2015, 09:56 PM   #18
prasimix's Avatar
Default Additional PCBs ...
Companion PCBs to the power board looks in this revision like this:
Old 6th February 2015, 12:14 PM   #19
Jaac is offline Jaac  Netherlands
Jaac's Avatar
Nice PCB Job. Where can we buy ?
The right tool for the right job, a very nice Solarboat || Ready for a groupbuy ? CLick
Old 6th February 2015, 02:21 PM   #20
prasimix's Avatar
Not so soon but shortly after I finalized testing of all functionality and make additional optimization and hopefully decrease number of components where possible. My intention is to first make functional, robust and stable power board which can be controlled manually (using pots and switches) and after that we can continue to play with MCU and Arduino-like code in case of the presented MCU board. Of course any suggestion regarding current design is highly welcomed.
DIY programmable dual channel bench PSU 0-50V/3AHide this!Advertise here!
DIY Dual Channel Active Tube Tone Control HideawayStudio Tubes / Valves 1 1st November 2010 01:05 PM
Good DIY Bench PSU for Solid State Gavinator68 Solid State 18 25th August 2008 05:33 PM
Programmable Bench Power Supply? samsagaz Parts 1 22nd January 2008 02:21 AM
Bench PSU sorenj07 Tubes / Valves 5 19th February 2007 10:53 PM
ESP project 3A amp at +/-50V Freddie Solid State 6 6th January 2002 02:54 AM
Copyright ©1999-2019 diyAudio
