Equipment & Tools From test equipment to hand tools
DIY programmable dual channel bench PSU 0-50V/3A
Old 31st October 2016, 01:44 PM   #161
prasimix is offline prasimix  Croatia
prasimix's Avatar
Originally Posted by Algar_emi View Post
I'll put the connector on the other side then. Still waiting for the delivery of the last few parts to try the boards. The diode DFLS1100-7 is still B/O at Mouser, but they are expected soon...
Perhaps you can try with some other in the same package e.g. SBR1U200P1-7, DFLS1200-7, etc.
Old 10th November 2016, 09:49 PM   #162
Algar_emi is offline Algar_emi  Canada
Algar_emi's Avatar
Got the parts, starting test of the AUX and PWR boards. SB
AUX_PS all ok, checked 12V, 5V switching supply, AC Softstart, now the PWR boards.
Old 15th December 2016, 12:59 AM   #163
Algar_emi's Avatar
Completed the supply at last. I had a few wrong part because I kept using my custom BOM built from one of the first version of the official BOM. There was errors in it, so I ended up buying some incorrect parts. But now the BOM is mature with no error.
Then I started each PCB, starting from the from the Arduino Shield. Test it with a 5V supply, I had to reverse all red leds that are incorrectly marked, there was a mods published for that. Programmed the Arduino, but I was not able to save the display calibration. After close inspection some configuration jumper were not making contact, I used short lenght of wire. Replaced then with the proper SMD 0R jumper, and the display was working fine.
Then the rear Auxiliary supply, tested by itself. and everything was ok.
Finally both Power PCB. There was assembly errors on those, some incorrect resistors values (from the BOM), unsoldered parts ends, bad solder junction from high current pads, etc... Using the supplied testing procedure I was able to make both board working.
Then I put everything together, but surprise I was getting fault from both Power PCB at startup, and the Arduino was shuting back to standby. Problem was that the AC/DC main power supplies were not ON at startup, so it was normal that both PWR PCB, supplied from these were not working at startup!
Took me a little while to find IC31 was not working, AND gate output was always off, even with two high at the input. Replaced it, and Voilą! the power supply was working.
It was a great troubleshooting experience, and you can't beat soldering 800 smd parts, to learn how to mount them
The designer team was of a great help during my troubleshooting, with sometime custom testing programs, suggestions, and proposed tests. It was a great experience.
Thanks guys.
Here my supply pictures
Old 15th December 2016, 06:53 AM   #164
prasimix's Avatar
Congratulations! It's nice to see that someone else successfully replicate it.
Hopefully it will works as intended and that firmware will do its job.
It will be also interesting to hear of your experience about programming output values with this "encoderless" front panel. Many people think that a programmable power supply must have an encoder (or two, or four) .
Old 19th December 2016, 01:11 PM   #165
Algar_emi's Avatar
Not at all, the graphical interface works great, and there is no neal for any other control.
Old 29th December 2016, 12:39 PM   #166
prasimix's Avatar
Default M3 firmware is released...
The firmware M3 is released today. We had some interesting time when for the first time a more then one interrupt is used and spent almost a month trying everything to make operation stable and predictable. Finally we found that Arduino's SPI transactions doesn't masks interrupts properly and we have to see what Arduino team will say. Another interesting thing was related to coupling channels outputs in series and parallel. It's not so straightforward as one can think because this power supply has down-programmer circuit that can make some problem when channels are coupled in series and enters CC mode or when coupled in parallel and enters CV mode. I'll prepare a video to show what could be happen as we solved that successfully.
With this firmware we covered almost everything on hardware level (only digital input, and load/batter NTC are not addressed). Please find below the main features of this release. Shown screenshots are from software simulator. All yellow painted text represents enabled/"clickable" options (in a "follow the yellow brick road" manner).
Channel coupling
Allows doubling of max. output voltage (up to 80 V) or current (up to 10 A). Outputs are wired internally thanks to two MCU managed power relays. Presentation and programming of output values and protections are unified/centralized.
Click the image to open in full size. Click the image to open in full size.
Tracking mode
Presentation and programming of output values and protections are centralized. When any protection tripped on one channel it will shut off both channel. Output enable/disable function is also unified.
Additional system protections
AUX temperature sensor settings
Lock local console (touch screen)
When locked only unlock icon is enabled. Lock can be protected with system password.
Sound control
Old 2nd January 2017, 11:51 PM   #167
Algar_emi's Avatar
Latest release is quite stable and a pleasure to use. Thanks guys.
SB
Old 3rd January 2017, 12:44 PM   #168
prasimix's Avatar
Thanks for that. The issue with multiple interrupts generated by SPI and non-SPI sources are still open, and currently in the M3 release the "collateral damage" is that communication with Ethernet controlled stopped to work. A new topic is opened on the Arduino forum and we'll see if someone will come with suggestion or idea what is going on. Of course, in the meantime we'll continue our investigation.
Old 3rd January 2017, 03:39 PM   #169
Algar_emi's Avatar
Indeed, just tried the Ethernet, and no luck, no longer working...
SB
Old 3rd January 2017, 03:42 PM   #170
prasimix's Avatar
SB
I know, to override that please add the following into the conf_user.h file:
Code:
#undef OPTION_ETHERNET
#define OPTION_ETHERNET 0
DIY programmable dual channel bench PSU 0-50V/3AHide this!Advertise here!
DIY Dual Channel Active Tube Tone Control HideawayStudio Tubes / Valves 1 1st November 2010 02:05 PM
Good DIY Bench PSU for Solid State Gavinator68 Solid State 18 25th August 2008 06:33 PM
Programmable Bench Power Supply? samsagaz Parts 1 22nd January 2008 03:21 AM
Bench PSU sorenj07 Tubes / Valves 5 19th February 2007 11:53 PM
ESP project 3A amp at +/-50V Freddie Solid State 6 6th January 2002 03:54 AM
Copyright ©1999-2019 diyAudio
