Equipment & Tools From test equipment to hand tools
Differential Probe - Reverese Engineered
Thread Tools
Old 11th June 2019, 02:05 PM   #41
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Yes you can use much larger caps, as long as they are the right ratio. But then your input Z gets much smaller than what you expect based on the resistors. Normally you try to keep all capacitances as small as practical.
Jan
Old 11th June 2019, 03:33 PM   #42
Slobodan covek is offline Slobodan covek  Serbia
Thank you.
Yes, ratio of capacitance is the same as those of the resistors.
Old 11th June 2019, 03:55 PM   #43
jan.didden's Avatar
Yes, impedance ratio is the same which normally means the cap to resistance value is inverse ratio.
Jan
Old 12th June 2019, 02:42 AM   #44
PRR is offline PRR  United States
PRR's Avatar
Originally Posted by Slobodan covek View Post
...simulations in TI Tina, and my input divider stage dos not attenuate the signal amplitude at all regardless of the frequency (tried 200 MHz max)....?
Does for me (PSpice). Above 1KHz it is near exact 10:1 attenuation. Below 30Hz it is a small hair more (round-off error in your 444.44... resistors).
However as you and Jan say, at high frequency the input impedance gets very-very low due to the roughly 1,000 pFd equivalent input capacitance. A lot of things which actually work OK will work poorly when 10 Ohms reactance (@ 70MHz) loads it.
My C46 should probably be 50pFd, or even 5pFd, with a few-pFd trimmer. And all other caps in proportion. Then input impedance would be hundreds of times higher.
Old 23rd October 2019, 04:07 PM   #45
Chupacabras is offline Chupacabras
Originally Posted by underwurlde View Post
^ OK, as requested... (apologies for low quality images)
pdf of THP version of the differential probes:
Attachment 391348
pdf of SMT version of the differential probes:
Attachment 391347
These differential probes I have reverse engineered are:
Testec type: TT-SI9001
1:10 / 1:100 attenuation
25MHz bandwidth.
Input:
±700V @1/100
±70V @1/10
DC & Peak AC
1000Vrms MAX, CAT III
Output:
<= 7V Max into 2K
The supply is 6V (via 4 AA batteries).
Thanks for those schematics, good stuff to learn for me.
I have simulated it in LTspice (used much better opamp instead of 741).
Unfortunately the simulations look like these circuits do not work properly.
-3dB bandwidth is about 9MHz.
Am I missing something?
  Reply to this post
Differential Probe - Reverese EngineeredHide this!Advertise here!
Thread Tools
Differential probe recommendations Jaimo Equipment & Tools 6 18th April 2013 10:20 AM
Can this enclosure/speaker be reverse engineered? Sneasle Multi-Way 13 2nd April 2013 01:03 AM
diy differential probe? zilog Class D 7 18th April 2006 10:42 PM
Engineered quartz as front baffle mbutzkies Multi-Way 2 28th October 2004 12:11 AM
T+A T160E bass XO reverse engineered -> improvements? capslock Multi-Way 7 12th August 2002 12:35 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
