Equipment & Tools From test equipment to hand tools
Differential Probe - Reverese Engineered
Thread Tools
Old 22nd April 2016, 04:57 PM   #21
bading is online now bading  Italy
The ground circled in red are the same or the ground of the high voltage signal is isolated ?
Thank's
Dario
Old 25th April 2016, 09:31 AM   #22
underwurlde is offline underwurlde  United Kingdom
Is the same (common) ground.
Old 28th July 2016, 09:04 AM   #23
Mauby is offline Mauby
Nice work!
I would like to build 4 of these for my works at home.
Do you have some pictures from the pcb, so that i could get an idea of the design ?
Old 12th October 2016, 01:38 PM   #24
COSMOS2K is offline COSMOS2K
Excellent project and excellent reverse engineering.
Thanks for sharing.
Greetings.
Old 12th February 2017, 10:36 PM   #25
Armadillo is offline Armadillo
Anyone has the BLM700 datasheet?
Old 14th February 2017, 02:26 PM   #26
Calvin is offline Calvin  Germany
Calvin's Avatar
here´s an interesting DIY build of a Diff-Probe:
click here
jauu
Calvin
My Website
Old 7th April 2017, 06:20 PM   #27
engenius is offline engenius
Default U3 substitutes and spares
first of all I´d like to thank underwurld for sharing his work results.
I just bricked my SI-9000 (THT version) by accidently applying 30V revers voltage to the output when calibrating it :-(
The output buffer OP amp (U3) had gone. As the code had been sanded off and the part has quite some demanding specs, a suited spare wasn’t easy to find.
Some types mentioned in this forum (AD797, etc.) won´t probably work, because they use V+ instead of V- referenced offset adjustment.
After spending some time investigating, I figured out these typed:
AD817
AD847
LM6361
LT1357
LT1360
LT1363
All of these have at least 25 MHz bandwidth, 300V/µs slewrate and low noise. I will give the LT1360 a try because it´s availability and price (about 4 EUR/1) and its excellent specs.
In the meanwhile, I run the SI-9000 with a TL081 (crappy 100 kHz bandwidth)
Old 10th April 2017, 09:42 PM   #28
emocabras is offline emocabras
Hello I write from Italy, you very good great job reverse engineering.
probe power supply be your creation or integrated probe?
I can feed with different dual power supply 9v battery 500mah
resistors marked point have tolerance 1%?
What power Watts have resistances this circuit?
You can publish original probe picture layout component
Old 25th July 2017, 07:34 PM   #29
Coyote973 is offline Coyote973
@underwurlde : Great post!
Perhaps adding a photo of other PCB side and how compensating capacitor are arranged (under resistor divider) would make even more clearer (if your device is still apart).
I took a look on schematics SMD type, but I think that R40 is somehow positioned in wrong way. I have searched many current mirrors, Wilson, Widlar,...any current mirror that exists, and haven't found any such mirror that has a resistor in that place.
The listed components are quite old and difficult to find. The U441 is now produced by Linear Systems. I wish I could understand the principles of the weird pair jfet + bjt.
Old 26th July 2017, 08:27 AM   #30
R.I.P.
Underwurlde,
Can you attach your pics now lost from posts 1 & 2?
regards Andrew T.
Differential Probe - Reverese EngineeredHide this!Advertise here!
Thread Tools
Differential probe recommendations Jaimo Equipment & Tools 6 18th April 2013 10:20 AM
Can this enclosure/speaker be reverse engineered? Sneasle Multi-Way 13 2nd April 2013 01:03 AM
diy differential probe? zilog Class D 7 18th April 2006 10:42 PM
Engineered quartz as front baffle mbutzkies Multi-Way 2 28th October 2004 12:11 AM
T+A T160E bass XO reverse engineered -> improvements? capslock Multi-Way 7 12th August 2002 12:35 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
