Equipment & Tools From test equipment to hand tools
QuantAsylum QA400 and QA401
Old 7th August 2016, 06:10 PM   #2081
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Yes when I am ready I can see if there is interest in a Group Buy. If I can get say 50 or so made that would make the price much more friendly!
Especially for the box and PCBs, and a few relatively expensive items like the AD536 AC-to-RMS converter.
Jan
Old 7th August 2016, 06:11 PM   #2082
mkc is offline mkc  Denmark
Hi Jan,
Looks very nice. Depending on price I would be interested. Although I have a Shibasoku 725C here awaiting to be hot-rodded "davada" style.
Mogens
Old 7th August 2016, 06:20 PM   #2083
davada is offline davada  Canada
R.I.P.
Jan
You're getting the level of a sine waveform. Do you really need to use an RMS detector.
I'm not familiar with this particular pic.Most of them come with at least a 10bit ADC.
You can sample the peak of the sine and convert to equivalent RMS.
Even a cheap peak detector would work for this. Or generate a quadrature from the fundamental and zero crossing detector to trigger ADC.
David.
Old 7th August 2016, 06:32 PM   #2084
R.I.P.
Originally Posted by mkc View Post
Hi Jan,
Mogens
Buy a cache of op amps now because they could disappear in a year or so the way things are going.
David.
Old 7th August 2016, 06:48 PM   #2085
31697B is offline 31697B  Thailand
Maybe a cheaper way would use a auto-scaling DVM IC and drive relays to affect input attenuator instead of the display. Or even cheaper would be an attenuator built around the multi-comparitors in the LM3914.
THx-RNMarsh
PIC16F688 Digital Voltmeter - Electronics-Lab
http://www.kitelectronica.com/2016/0...14-lm3915.html
Old 7th August 2016, 06:55 PM   #2086
R.I.P.
THx-RNMarsh
Tutorial circuito integrado LM3914 LM3915. - Kits de electrónica y circuitos.
Interesting. One could add log function to get dBV.
David.
Old 8th August 2016, 03:30 AM   #2087
benb is offline benb  United States
Yes, the numbers.
The max input is 100V RMS (140V peak) so you can directly measure power amp output. Min. input around 150mV. Between those levels the autoranger will deliver around 1V to your soundcard. Fully automatically.
Freq response is flat to 100 kHz at +/- 0.1dB. Distortion -120dB. That should be OK for all those sound cards out there.
To help with setup, the display shows the actual level going into the soundcard and the autoranger input level and attenuation or gain setting applied.
Atten/gain ranges from -40dB to +16dB.
Jan
Dare I ask how fast this thing switches between levels? What will a soundcard see if the input goes from 0V to a 140Vp 20KHz sinewave?
Old 8th August 2016, 07:15 AM   #2088
jcga is offline jcga  France
Hi Jan,
exactly what I was looking for !
Count on me for one piece...
Best
Jean Claude
Old 8th August 2016, 07:27 AM   #2089
jan.didden's Avatar
Attenuation rate is about 100dB per second. But the output is limited to a safe value so such a step won't be a problem.
Jan
Old 12th August 2016, 04:30 PM   #2090
Robbo67 is offline Robbo67  Australia
Robbo67's Avatar
Send a message via MSN to Robbo67
Originally Posted by jcga View Post
Hi Jan,
Best
Jean Claude
Me too!
Just what I'm looking for to match my QA401
QuantAsylum QA400 and QA401Hide this!Advertise here!
QuantAsylum 401 & 405 B&W_arthur Equipment & Tools 5 22nd March 2016 04:27 PM
QA190 and QA400 Gains sgtnoah Equipment & Tools 4 17th July 2015 03:46 AM
Question on QA400 Alan0354 Equipment & Tools 7 10th July 2015 06:34 PM
FS QuantAsylum QA400 audio analyser jan.didden Swap Meet 3 29th September 2014 05:10 PM
New Quantasylum QA190 Differential Input Probe stellavox Equipment & Tools 3 20th March 2014 06:06 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
