Equipment & Tools From test equipment to hand tools
QuantAsylum QA400 and QA401
Old 1st August 2016, 03:48 PM   #2061
1audio is offline 1audio  United States
I would like a copy of the file. I will PM my e-mail. A test like that could show a lot about the performance of many audio stages.
Demian Martin
Product Design Services
Old 1st August 2016, 05:04 PM   #2062
31697B is offline 31697B  Thailand
Originally Posted by miklos View Post
Did it a couple of years ago in the Cool Edit.
I think it goes like this:
Generate - 44.1kHz 16 Bit - Noise - White - sec.
Effects - Filters - FFT - size 8192 - Blackman-Harris
I also could send you the wav file.
This is great.... finally an easy test which shows a lot of unwanted stuff... certainly more audible than single tone at <-100dB. I have this multi-tone ability on my AP-2722 but the setup is a long learning curve. Your method seems much easier and so I would like to try it as well.
Can you put your file up somewhere we can all get it or do I need to send you my email address?
THx- Richard Marsh
Old 1st August 2016, 05:48 PM   #2063
Davey is offline Davey  United States
Gents,
You can use Goldwave to generate that fairly easily. Use the "Spectrum Filter" function in the Filter section. There's a couple of presets there you can modify to fine tune to your liking.
Dave.
Old 1st August 2016, 05:50 PM   #2064
miklos is offline miklos  Hungary
miklos's Avatar
Here's the link:
https://drive.google.com/file/d/0B0T...ew?usp=sharing
21MB
miklos
Old 1st August 2016, 10:25 PM   #2065
Thx to both.
-RM
Old 2nd August 2016, 12:01 AM   #2066
miklos's Avatar
Originally Posted by benb View Post
It seems all that noise would be very effective at linearizing the A/D converter as well as dithering. You're likely to see something different than with just those tones themselves around 1kHz.
Would be nice to see some power amp measurements, CD's players I already did a lot of, maybe some of the newer DAC's , AK ,Wolfson or the Soekris one.
Possibly could help to settle the discussion about the single tone THD measurement relevance to. If deeper notch is needed ,one could repeat the exercise choosing higher sample rate and bit depth, and play the file trough the sound card.
miklos
Old 2nd August 2016, 01:07 AM   #2067
gazzagazza is offline gazzagazza  New Zealand
Thanks. Google made me request access to the file, so you will receive a request.
Old 2nd August 2016, 01:29 AM   #2068
miklos's Avatar
I don't understand, I put it up for free access.
I just checked, the link works for me.
miklos
Old 2nd August 2016, 08:55 AM   #2069
It might be because I shared the link from my Android device by Gmail to myself then clicked on it from my desktop. The shared link was via Tapatalk which I use to read forums on my phone. I'll check it again, I'm sure it will be ok. Thanks!
Sent from my x600 using Tapatalk
Old 2nd August 2016, 12:44 PM   #2070
Max Headroom is offline Max Headroom  Australia
Banned
Location: West Australia, near to the beach, natural ambient sounds mostly.
.....Up to this point for more realistic testing ,more music like random signal is a noise with gap quite revealing, where anything in the bottom of the gap is distortion.
Nice work.
You have provided steep cutoff, band cut response.
Other revealings would be same steep cutoff Hp or LP filter at a bunch of cutoff frequencies.
The above mapping, plotted against power levels ought to be quite revealing.
Dan.
QuantAsylum QA400 and QA401Hide this!Advertise here!
QuantAsylum 401 & 405 B&W_arthur Equipment & Tools 5 22nd March 2016 04:27 PM
QA190 and QA400 Gains sgtnoah Equipment & Tools 4 17th July 2015 03:46 AM
Question on QA400 Alan0354 Equipment & Tools 7 10th July 2015 06:34 PM
FS QuantAsylum QA400 audio analyser jan.didden Swap Meet 3 29th September 2014 05:10 PM
New Quantasylum QA190 Differential Input Probe stellavox Equipment & Tools 3 20th March 2014 06:06 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
