Equipment & Tools From test equipment to hand tools
QuantAsylum QA400 and QA401
Old 18th June 2016, 02:47 PM   #2051
Davey is offline Davey  United States
Not a big deal, but one thing I did note when FR testing is the pulse on the "+" outputs is negative going.
Dave.
Old 23rd June 2016, 10:25 AM   #2052
miklos is offline miklos  Hungary
miklos's Avatar
I managed to screw up my QA400 by discharging a 15000uF -40V capacitor through a ground loop, something like this: amplifier - input w a 25k pot turned to zero - QA400 input ground - QA400 USB con. - Computer GND - my grounded soldering iron touching the -40V . Lucky me only two IC-s burnt in it, a low dropout adj. reg. U13 and a boost converter U10 producing the +10V for the analog stages. The whole exercise cost me some nerve wrecking moments, because I don't have $550 for a QA401 and $60 for the parts from Digikey.
File Type: jpg Adjustable low voltage drop regs U13-14-15.jpg (513.1 KB, 717 views)
miklos
Old 23rd June 2016, 10:16 PM   #2053
davada is offline davada  Canada
R.I.P.
I surprised this didn't shut down the USB power before any damage. A ground fault should have just burned some thin trace on the ground.
David.
Old 24th June 2016, 06:20 PM   #2054
miklos's Avatar
The damage doesn't come from the USB power, it come from the -40V. Once the U13 get shorted, the +5V USB shut down. The U13 low dropout reg. is directly connected to the USB power, the U10 boost converter has the L1 coil in series to the +5V.
miklos
Old 30th June 2016, 07:34 AM   #2055
31697B is offline 31697B  Thailand
From the HP-339 mod forum.... we used an external notch filter to atten the signal to the ADC for greater linearity in measurement apps. I found a passive notch filter (nill distortion) from B&K 1607. Then I got some help/suggestion on converting it to active for sharper notch width. I have it switchable -- active-passive mode.
Here is the before and after mod affect:
THx-RNMarsh
Old 5th July 2016, 12:17 PM   #2056
miklos's Avatar
Is anywhere this mod described in details, link?
Thanks.
miklos
Old 31st July 2016, 10:04 PM   #2057
miklos's Avatar
Silence on the thread, everybody is on vacation.
Here's a little story how I used my QA400 in the last three years and also learned a lot by reading here how to use the QA correctly.
Many forum members disregarding THD measurements as not being relevant to sound quality.
I for one believing in meters, I'm not testing the mains with my tongue, why should I completely trust my ears?
The nice added distortions can foul one easily. So I compared CD players from the cheapest one to the pretty expensive one, from the first generation like the Hitachi DA1000 with a ceramic PCM53 from 1982 to the latest generations mega bucks Esoteric's and everything in between. For me it's easier to see the differences between them than hear it. The Redbook CD is pretty robust system, working well, like the FM radio. In my search I found what I was looking for, the best deal you can have on a player, to buy a 10-15 year old DVD player, those are shed by the owners in favor of the Blue ray ones.
Try the Pioneer DV-45, DV-47Ai or the Sony DVP-S9000es, fantastic players, with hard to beat specs.
An other subject comes up to time to time, that THD is done on a static signal, what music is not. I tried multi tones with
the QA400, like 6 or 12 tones, no numerical result, just visible one. I can see ca. 10dB rise of the noise floor going from 6
to 12 tones. Probably caused by IMD and the increased jitter. Up to this point for more realistic testing ,more music like
random signal is a noise with gap quite reviling, where anything in the bottom of the gap is distortion. Here's a picture of a
test on a ca. 20-23 years old Philips CD921 (TDA-1549 DAC) with the white noise with gap signal.
miklos
Old 31st July 2016, 10:50 PM   #2058
1audio is offline 1audio  United States
How did you generate that file with such a sharp transition to the silent band? I could use that trick.
Demian Martin
Product Design Services
Old 1st August 2016, 01:29 PM   #2059
miklos's Avatar
Did it a couple of years ago in the Cool Edit.
I think it goes like this:
Generate - 44.1kHz 16 Bit - Noise - White - sec.
Effects - Filters - FFT - size 8192 - Blackman-Harris
I also could send you the wav file.
miklos
Old 1st August 2016, 03:44 PM   #2060
benb is offline benb  United States
It seems all that noise would be very effective at linearizing the A/D converter as well as dithering. You're likely to see something different than with just those tones themselves around 1kHz.
QuantAsylum QA400 and QA401Hide this!Advertise here!
QuantAsylum 401 & 405 B&W_arthur Equipment & Tools 5 22nd March 2016 04:27 PM
QA190 and QA400 Gains sgtnoah Equipment & Tools 4 17th July 2015 03:46 AM
Question on QA400 Alan0354 Equipment & Tools 7 10th July 2015 06:34 PM
FS QuantAsylum QA400 audio analyser jan.didden Swap Meet 3 29th September 2014 05:10 PM
New Quantasylum QA190 Differential Input Probe stellavox Equipment & Tools 3 20th March 2014 06:06 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
