Equipment & Tools From test equipment to hand tools
Tube tester
Tube tester
Old 15th January 2013, 12:49 PM   #31
molekuul is offline molekuul  Netherlands
That's why good tube testes have an adjust knob for calibrating the tester to the line voltage.
Old 15th January 2013, 01:47 PM   #32
nickds1 is offline nickds1  England
nickds1's Avatar
Originally Posted by TheGimp View Post
In addition to the cal issue, I seriously doubt that more than a hand full of people selling tubes are using a variac to adjust the voltage to the tube tester. Running on high line (current line voltage is above what they were designed for), the heater voltage is too high, causing false readings.
The uTracer compensates for all that - has an ADC that reads the supply voltage so it gets its maths right on PWM etc... the screen & anode voltages are generated from on-board SMPS supplies, so are unaffected too.
Nicko
"The whole plan hinged upon the natural curiosity of potatoes" - S. Lem
Old 15th February 2013, 07:28 PM   #33
tubelectron is offline tubelectron  France
Nothing...and I mean nothing, substitutes sticking a tube in a circuit designed for that tube and seeing how it performs under actual operating and load conditions...especially when you have a known good tube to compare it against....
Oh... It seems that you've discovered hot water, indeed ! And when you have an Ampeg SVT, an Ashdown BTA-400 to service, with 6 to 8 6550 or KT88, your substitution trick can turn to a fireworks for a brand new set of these costy tubes. So you need a tube tester, and a good one, well-calibrated, even if it is a simple emission tester as my NRI-70 below, that I bought for cheap :
Tube tester
But yes, an uncalibrated Hickok 539B or C is nothing more than a nice toy... And most of them need a serious calibration job ! It would be more easy to calibrate and check if the Hickoks complied to the tube datasheet - like my Metrix 310CTR - instead of relying on an always questionable proprietary tube chart...
A+!
Tube testerHide this!Advertise here!
WTB: Tube IMP or VTV Tube Tester or? bmenary Swap Meet 8 24th July 2011 10:39 AM
Tube Tester maxseeley Equipment & Tools 0 5th January 2011 05:08 AM
Help finding a tube tester for Stereo tube amps. Fasterdamnit Tubes / Valves 8 19th July 2010 01:43 AM
Tube Tester jtwrace Equipment & Tools 5 8th September 2007 04:47 PM
help using Tube Tester ebarker2 Equipment & Tools 3 31st January 2004 02:30 AM
Copyright ©1999-2019 diyAudio
