phofman
According to the link below, USB2 utilises 8 Microframes (125us) per USB1 frame (91ms)
https://www.usbmadesimple.co.uk/ums_6.htm
George
George
USB device (endpoint) specifies how often it expects/sends data, in USB descriptor bInterval. For USB2 highspeed (i.e. the E-MU) the value gives multiples of 125us microframes (125us, 250us, 500us, 1000us). Devices typically support several channel/samplerate/bInterval combinations - called alternate settings (altsets). When the driver opens the device it selects which altset will be used. Shorter packet interval means lower latency.
Linux lists these altsets for my E-MU 0404USB:
Please note that the device supports many combinations of channels/samplerates, nice. All combinations are available in 500us packet interval, those combinations that fit 1000us interval (adhering to the 1024 bytes per frame isochronous limit), are also available in that interval (to spare CPU and limit risk of underflows).
Linux USB driver picks the longest packet interval available, hence I cannot force the 500us interval for 48kHz. Likely your ASIO driver picks 500us (correctly, as ASIO focuses on latency) and therefore the artefacts of 2kHz in your RTA, IMHO. Exact details would be visible in USB packet capture e.g. via wireshark.
Devices using 1000us packet interval often have 1kHz artefact. For USB devices it's better to measure with a signal not exactly 1kHz, so that the measurement harmonics do not ovelap with the USB artefacts in RTA.
Code:
E-MU Systems, Inc. E-MU 0404 | USB at usb-0000:02:00.0-8, high speed : USB Audio
Playback:
Status: Running
Interface = 1
Altset = 7
Packet Size = 586
Momentary freq = 96000 Hz (0xc.0000)
Feedback Format = 13.19
Interface 1
Altset 1
Format: S24_3LE
Channels: 2
Endpoint: 0x01 (1 OUT) (ASYNC)
Rates: 44100
Data packet interval: 1000 us
Bits: 24
Channel map: FL FR
Sync Endpoint: 0x81 (1 IN)
Sync EP Interface: 1
Sync EP Altset: 1
Implicit Feedback Mode: No
Interface 1
Altset 2
Format: S24_3LE
Channels: 2
Rates: 44100
Data packet interval: 500 us
Bits: 24
Channel map: FL FR
Sync EP Altset: 2
Interface 1
Altset 3
Format: S24_3LE
Channels: 2
Rates: 48000
Bits: 24
Channel map: FL FR
Sync EP Altset: 3
Interface 1
Altset 4
Format: S24_3LE
Channels: 2
Rates: 48000
Bits: 24
Channel map: FL FR
Sync EP Altset: 4
Interface 1
Altset 5
Format: S24_3LE
Channels: 2
Rates: 88200
Bits: 24
Channel map: FL FR
Sync EP Altset: 5
Interface 1
Altset 6
Format: S24_3LE
Channels: 2
Rates: 88200
Bits: 24
Channel map: FL FR
Sync EP Altset: 6
Interface 1
Altset 7
Format: S24_3LE
Channels: 2
Rates: 96000
Bits: 24
Channel map: FL FR
Sync EP Altset: 7
Interface 1
Altset 8
Format: S24_3LE
Channels: 2
Rates: 96000
Bits: 24
Channel map: FL FR
Sync EP Altset: 8
Interface 1
Altset 9
Format: S24_3LE
Channels: 2
Rates: 176400
Bits: 24
Channel map: FL FR
Sync EP Altset: 9
Interface 1
Altset 10
Format: S24_3LE
Channels: 2
Rates: 192000
Bits: 24
Channel map: FL FR
Sync EP Altset: 10
Interface 1
Altset 11
Format: S24_3LE
Channels: 4
Rates: 44100
Bits: 24
Channel map: FL FR SL SR
Sync EP Altset: 11
Interface 1
Altset 12
Format: S24_3LE
Channels: 4
Rates: 44100
Bits: 24
Sync EP Altset: 12
Interface 1
Altset 13
Format: S24_3LE
Channels: 4
Rates: 48000
Bits: 24
Sync EP Altset: 13
Interface 1
Altset 14
Format: S24_3LE
Channels: 4
Rates: 48000
Bits: 24
Sync EP Altset: 14
Interface 1
Altset 15
Format: S24_3LE
Channels: 4
Rates: 88200
Bits: 24
Sync EP Altset: 15
Interface 1
Altset 16
Format: S24_3LE
Channels: 4
Rates: 96000
Bits: 24
Sync EP Altset: 16
Capture:
Status: Stop
Interface 2
Altset 1
Format: S24_3LE
Channels: 2
Endpoint: 0x82 (2 IN) (ASYNC)
Rates: 44100
Bits: 24
Channel map: FL FR
Interface 2
Altset 2
Format: S24_3LE
Channels: 2
Rates: 44100
Bits: 24
Channel map: FL FR
Interface 2
Altset 3
Format: S24_3LE
Channels: 2
Rates: 48000
Bits: 24
Channel map: FL FR
Interface 2
Altset 4
Format: S24_3LE
Channels: 2
Rates: 48000
Bits: 24
Channel map: FL FR
Interface 2
Altset 5
Format: S24_3LE
Channels: 2
Rates: 88200
Bits: 24
Channel map: FL FR
Interface 2
Altset 6
Format: S24_3LE
Channels: 2
Rates: 88200
Bits: 24
Channel map: FL FR
Interface 2
Altset 7
Format: S24_3LE
Channels: 2
Rates: 96000
Bits: 24
Channel map: FL FR
Interface 2
Altset 8
Format: S24_3LE
Channels: 2
Rates: 96000
Bits: 24
Channel map: FL FR
Interface 2
Altset 9
Format: S24_3LE
Channels: 2
Rates: 176400
Bits: 24
Channel map: FL FR
Interface 2
Altset 10
Format: S24_3LE
Channels: 2
Rates: 192000
Bits: 24
Channel map: FL FR
Interface 2
Altset 11
Format: S24_3LE
Channels: 4
Rates: 44100
Bits: 24
Channel map: FL FR FC LFE
Interface 2
Altset 12
Format: S24_3LE
Channels: 4
Rates: 44100
Bits: 24
Interface 2
Altset 13
Format: S24_3LE
Channels: 4
Rates: 48000
Bits: 24
Interface 2
Altset 14
Format: S24_3LE
Channels: 4
Rates: 48000
Bits: 24
Interface 2
Altset 15
Format: S24_3LE
Channels: 4
Rates: 88200
Bits: 24
Interface 2
Altset 16
Format: S24_3LE
Channels: 4
Rates: 96000
Bits: 24
