Equipment & Tools From test equipment to hand tools
Low-distortion Audio-range Oscillator
Low-distortion Audio-range Oscillator Please consider donating to help us continue to serve you.
Old 22nd November 2019, 06:01 PM   #8101
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
I could try that!
Edmond, if you are reading this, how do I do that?
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio articles - SilentSwitcher - Treg high voltage regulator - High-voltage delay unit
Old 22nd November 2019, 06:04 PM   #8102
Edmond Stuart is offline Edmond Stuart  Netherlands
Edmond Stuart's Avatar
Default Notch filter compensation
Originally Posted by 1audio View Post
Jan, to push the envelope can you connect a soundcard to the notch monitor out from the AP and use Diana to look at just the harmonics? Edmund has a routine for correcting for the insertion loss of the notch. Diana can separate the harmonics and even reconstruct the phase accurate error.
But I'm still busy with this: DiAna, a software Distortion Analyzer
The problem is how to calculate or estimate the insertion loss at the fundamental by means of interpolation. Perhaps B-splines again?
Cheers, E.
http://www.data-odyssey.nl/
Old 22nd November 2019, 06:15 PM   #8103
Default Notch filter characterization
Originally Posted by jan.didden View Post
I could try that!
Jan
Hi Jan,
See: DiAna, a software Distortion Analyzer and further. However, be aware of possible pitfalls like overloading etc.
Cheers, E.
Old 22nd November 2019, 06:31 PM   #8104
phofman is online now phofman  Czech Republic
Edmond: in my distortion compensation project I tried estimating the RC filter component values by nonlinear regression (curve-fitting) of the respective circuit equations to the measured transfer values (amplitude and phase shift), initialized with imprecise values of the circuit components. Worked very precisely. Once the circuit model has the exact component values determined by curve-fitting, you can probe it for any parameter at any condition.
In your case the equations would be more complicated since the filter is a bit more complex, but you could offer a few typical circuits + user would enter the nominal component values. Good libraries can curve-fit complex values which makes the equations much simplier.
The equation for RC LPF was trivial with complex numbers nonlinear-compensation/lowPass.m at 078fb9f1c572568f343bb0bd652b2ea55874896d * pavhofman/nonlinear-compensation * GitHub
Finding exact values of R1, C1, Rin to fit the measured transfer values (in my trial just randomized exact values) were only several lines nonlinear-compensation/testLP.m at 078fb9f1c572568f343bb0bd652b2ea55874896d * pavhofman/nonlinear-compensation * GitHub
The core of my algorithm is based on nonlinear curve-fitting and the fitting precision is extremely good (sum of squared errors at 1e-20), of course provided the equations are correct.
I am sure it would work, especially if you let some software derive the equations for you.
Maybe some interpolation will work too, but definitely not as accurately as the circuit model fitted to measured values. On the other hand you do not need any major precision in your interpolation, it does not matter if diana measures values with a few percent of relative error.
Just 2 cents.
Old 22nd November 2019, 07:11 PM   #8105
jan.didden's Avatar
Originally Posted by Edmond Stuart View Post
Hi Jan,
Cheers, E.
I'll do that tomorrow. I understand the concept.
Jan
Old 22nd November 2019, 07:37 PM   #8106
diyralf is offline diyralf
diyralf's Avatar
Default Latest version of my THD calculator
Latest version of my THD calculator. What's new?
- Import possibility from ARTA
- Selection of harmonics
Old 22nd November 2019, 09:52 PM   #8107
jan.didden's Avatar
Ralf, I'm trying to figure out the calculations.
For H2, the measurement (I think) is -94.6dB. The notch atten for H2 is -8.8dB. So the actual H2 is then -85.8dB, right?
The amp gain is 40.1dB. That gives me -125.9dB. But the calculated column says -124dB. Maybe I miss something, but I can't solve it.
How do you do it?
Edit: if I figure in the atten from 600R Zout and 2.5k Zin I get the missing 1.8dB. But that would be for both the (notched) fundamental as well as the harmonics, so should make no difference. I think ...
Jan
Old 22nd November 2019, 10:31 PM   #8108
1audio is offline 1audio  United States
Edmund, could you enter the fundamental attenuation manually? What I did was plot the attenuation curve for harmonic correction and adjust for the loss/gain in the Shibasoku output which is fixed.
Demian Martin
Product Design Services
Old 22nd November 2019, 10:48 PM   #8109
diyralf's Avatar
How do you do it?
Jan
Your conclusions are correct. The value of the attenuated fundamental doesn't matter in the calculation. I do the calulation with the unattenuated input fundamental. This has the advantage that I don't need to know the fundamental attenuation of the notch filter. In addition, if the oscillator frequency deviates from the notch frequency, then the attenuation is different again.
Old 23rd November 2019, 07:53 AM   #8110
jan.didden's Avatar
But my point was that you have to (and I think you do) take into account the attenuation from DUT Zout and notch Zin, the 600R - 2.5k. Right? It is a fixed factor in your test setup.
Jan
Low-distortion Audio-range OscillatorHide this!Advertise here!
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 21 19th February 2014 11:46 AM
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 04:04 PM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 11:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 01:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 04:58 AM
Copyright ©1999-2019 diyAudio
