Equipment & Tools From test equipment to hand tools
Low-distortion Audio-range Oscillator
Old 10th August 2019, 10:00 AM   #7481
suzyj is offline suzyj  Australia
suzyj's Avatar
Originally Posted by triode_al View Post
research and disaster
They donít call it the bleeding edge for nothiní.
http://www.suzyj.net
Old 10th August 2019, 11:34 AM   #7482
triode_al is offline triode_al  Netherlands
triode_al's Avatar
What is most disastrous in my work is the research and divert phenomenon, where I 'invent' something and being brought off track, to divert up to a point of no return and then drop the whole thing. Sorry, this is OT.
ņ la recherche d'un son perdu
Old 10th August 2019, 01:33 PM   #7483
diyralf is offline diyralf
diyralf's Avatar
I think it doesn't matter if the frequency or the amplitude changes.This audio oscillator is used for audio measurements. Distortions only matter.
Old 10th August 2019, 06:36 PM   #7484
bozidarms is offline bozidarms  Switzerland
How does it look 1kHz signal derived from 10MHz GPS.
Well, here is the answer:
first picture presented a change in frequency of 1kHz over time
and second is a histogram of same 1kHz signal
Signal vary less than 260u(micro)Hz, and whole frequency span is only 500uHz wide.
Signal shows exceptional spectral purity and stability.
Even more fascinating is histogram of 10Hz signal derived from same 10mHz GPS:
Note the frequency span of only 50n(nano)Hz and freq.variation is not more than 27nHz!
I apologize for those whose are not interested in this matter ,but i am just fascinated with measurements.
Old 11th August 2019, 12:15 AM   #7485
1audio is offline 1audio  United States
Actually in a sense frequency and amplitude changes are distortions. An RC network will not have enough Q to get the really narrow spectrum that a crystal oscillator can. However I'm not sure a tuning fork crystal would have the necessary Q either at 1 KHz.
I explored injection locking an oscillator but when I got it to lock the distortion shot up. The best approach might be what Boonton did with a PLL loop going into a tuning analog multiplier on the state variable. It works well but the analog multipliers are a limitation in overall performance. Still I get very good frequency stabilization and .01Hz resolution and accuracy with .0006% THD+N.
Demian Martin
Product Design Services
Old 11th August 2019, 02:15 AM   #7486
anatech is offline anatech  Canada
anatech's Avatar
Hi Demian,
I also tried injection locking an oscillator and ran into the same issues no matter what I did. I did not go as far as you did. It was clear that very low distortion and injection locking wasn't going to work well. Not for me anyway.
-Chris
"Just because you can, doesn't mean you should" © my Wife
Low-distortion Audio-range OscillatorHide this!Advertise here!
Radford Low Distortion Oscillator Series 2 audiomik Equipment & Tools 21 19th February 2014 10:46 AM
ultra-low distortion audio oscillator geekysuavo Analog Line Level 16 26th March 2013 03:04 PM
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 10:45 PM
Can we improve this low distortion sine oscillator ? gaetan8888 Solid State 22 29th March 2009 12:30 PM
Simple, low distortion 1kHz oscillator jackinnj Solid State 4 6th October 2003 03:58 AM
Copyright ©1999-2019 diyAudio
