usb audio interface
Thanks for the answers.
However, these models have standard specifications:
input dynamic range: 100dB (typical, -60dB input, A-weighted)
signal-to-noise ratio: 100dB (typical, A-weighted)
In order to evaluate the specifications of other sounds cards and mp3 players,
I would need to have much higher measures than these standard ones.
Is there any other product that I could use?
David
Is someone says "DUT test" or "DUT testing" or "what DUT are you testing" i will reach across the internet with my soldering iron.
Sorry i just have a test at work that literally says "Please do not touch the DUT testing please".
Ok some one else can vent about hot water heaters now.
frugal-phile™
Joined 2001
Yes it does (24/192) and can even do 32 bit measurements.
Not in practise (at least for me): "Macintosh analog operation up to 96kHz and digital operation up to 48kHz only at this time."
It does 32 bit internal processing with 24 bit I/O. I expect that that is pretty common as it is the most sensible way to use the 32bit wide processors.
dave
So, the Edirol uses CS5340 ADC and AK4385 DAC.
The E-MU 0404 uses AK5385A ADC and AK4396 DAC
The specs just looking at the datasheet shows what's theoretically possible.
E-MU 0404 in 32/96
E-MU 0404 in 24/96
Edirol FA66 (I cannot find my graphs for this one, but these are within +-0.2dB of what I remember, despite the sampling rate difference:
