Equipment & Tools From test equipment to hand tools
Test & Measurement interface for Soundcard
Thread Tools
Old 21st February 2021, 03:28 PM   #951
Rax is offline Rax  United States
Hi all!
Having switched to an AP box a while ago, my unit is up for grabs. I will consider any reasonable offers.
Old 13th March 2021, 06:25 PM   #952
Default Sold!
Earlier in the week.
Old 9th April 2021, 06:59 PM   #953
Mello4 is offline Mello4  United States
Originally Posted by jan.didden View Post
Not to beat my own drum, but a SilentSwitcher from the diyaudio store, fed by a Powerbank, will completely cure that.
Jan
Are you aware of anyone putting your Silent switcher board inside the Bud case that Peter Millett selected for his sound card interface? I am considering where to mount it for that Bud case Peter selected (which is pretty small) and USB connector hole is already placed.
Old 15th May 2021, 04:28 PM   #954
JLesterP is offline JLesterP  Philippines
Here's the loopback measurement of my Motu M4.
(Single ended) Monitor out #2 to Line-In #4 (-IN tied to GND)
Asio driver 48kHz sample rate
File Type: png Motu M4 loopback SE Mon 2, Line-IN 4.PNG (115.9 KB, 277 views)
www.jlelectronicsph.com
Old 15th May 2021, 08:28 PM   #955
bucks bunny is offline bucks bunny  Germany
THD+N looks excellent to me. Which analyzing sw did you use?
Old 16th May 2021, 08:16 AM   #956
Looks like I posted in a wrong thread. Anyway, I'm using REW software
Old 21st July 2021, 03:15 PM   #957
keland is offline keland  United Kingdom
Default Did you try the FDH300s?
This issue has also been discussed here. I assume 1N4148s that are used in Pete's soundcard interface have too high leakage. Next I will try the FDH300s that Jan Didden is using in his AutoRanger.
Old 21st July 2021, 05:35 PM   #958
If it is a leakage issue, the Nexperia BAS45A diode has very low leakage (1nA), but one may have an issue with excess junction capacitance (which is voltage dependent). The BAS45A diode has lower junction capacitance than the FDH300 diode.
Old 22nd July 2021, 07:56 AM   #959
bohrok2610 is offline bohrok2610  Finland
Yes, I switched to FDH300s. They work as expected i.e. THD above 10kHz is much lower than with the original 1N4148s.
/Martti
Old 22nd July 2021, 08:02 AM   #960
I also switched the opamp to OPA1656. That lowered the noise floor and THD as well.
Test & Measurement interface for SoundcardHide this!Advertise here!
Thread Tools
Recommendations on pc audio interface for loudspeaker measurement diypole Multi-Way 9 15th July 2009 12:45 PM
Request for advice / high performance soundcard for measurement Gordy Solid State 8 14th February 2008 04:14 PM
MCM Speaker Measurement Interface / USB Woofer Tester sdclc126 Multi-Way 0 17th January 2007 01:00 AM
Tenma Speaker Measurement Interface johngalt47 Multi-Way 1 6th January 2007 02:17 AM
Soundcard interface. Mr Evil Everything Else 5 12th July 2005 11:38 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
