Equipment & Tools From test equipment to hand tools
Test & Measurement interface for Soundcard
Old 5th August 2019, 01:46 PM   #911
phredrick is offline phredrick
csv is attached - the csv is simply an extract of info from Pete's BOM which seems to work with digikey's BOM import function on their webpage.
The import function dumps out a list which has to be inspected/corrected for out of stock items. No big deal but a little attention to detail is important. I kept Pete's BOM open in a spreadsheet window to reference while going through the list on digikey's website. Order quantity changes and parts substitutions can be made to the list so you can purchase exactly what you want.
Another thing to do is register as a customer prior to doing the import so the BOM can be saved and the purchase made at a later time. Handy if you want to get prices from a couple of vendors.
Old 5th August 2019, 07:06 PM   #912
bikinpunk is offline bikinpunk  United States
Just in case anyone here wants to save themselves some time, I listed my PM soundcard interface up for sale this morning. I purchased it from a forum member two weeks ago but had a car issue that I had to get repaired so I need to sell the interface to recoup some of that repair fee. Being an adult sucks.
Anyway, here's the link just in case anyone is interested. Asking what I paid for it.
FS: Assembled Sound Card Interface / AC RMS voltmeter by P. Millet
Old 6th August 2019, 02:09 PM   #913
itsikhefez is online now itsikhefez  United States
Originally Posted by itsikhefez View Post
I generated a 60hz sine wave in ARTA with my DMM connected to GEN OUT.
With GenMon enabled, rotating the range switch changes the measured voltage.
For example, range is set on 20V and both my DMM and interface show 3.06V.
If I rotate the switch to 2V, the interface shows the overrange sign, and my DMM shows 4.3V.
So the display is correct, the issue is that changing the range with GenMon changes the measured voltage.
I am assuming this is not expected?
Can anyone confirm if this is the expected behavior or not?
If rotating the range knob changes the input impedance then I guess the measured voltage should change as well (given the soundcard is generating a constant signal)
Old 6th August 2019, 02:13 PM   #914
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
You may overdriving a stage in the unit by going to a lower range which switches in more gain. If you look at the signal you probably see it is clipped. Check the circuit diagram what happens when you switch ranges.
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 11th August 2019, 03:07 PM   #915
MagicBus is offline MagicBus  Greece
MagicBus's Avatar
As requested Behringer UMC 202HD for measurements
Test & Measurement interface for SoundcardHide this!Advertise here!
Recommendations on pc audio interface for loudspeaker measurement diypole Multi-Way 9 15th July 2009 12:45 PM
Request for advice / high performance soundcard for measurement Gordy Solid State 8 14th February 2008 04:14 PM
MCM Speaker Measurement Interface / USB Woofer Tester sdclc126 Multi-Way 0 17th January 2007 01:00 AM
Tenma Speaker Measurement Interface johngalt47 Multi-Way 1 6th January 2007 02:17 AM
Soundcard interface. Mr Evil Everything Else 5 12th July 2005 11:38 PM
Copyright ©1999-2019 diyAudio
