Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Equipment & Tools From test equipment to hand tools |
Thread Tools |
#811 |
It must have been picking up the mains from the environment.
I have thin sheets of mu metal stuck to the inside of the top, bottom and sides of the case. I linked the side pieces to the top and bottom sheets with blobs of solder and earthed them which I hadn't done before. The mains hump has disappeared altogether. This is without the higher performance components. I included these when I ordered all the parts so I might as well fit them. Loopback spectrum -30dB 230mV earthed mu metal shield.png |
#812 |
Well done. I did not know your enclosure was not fully shielded.
For shielding smaller non-conducting enclosures or compartments a solderable copper tape has been of great help to me 50mm x 3m EMI Copper Foil Shielding Tape Conductive Self Adhesive Barrier Guitar | eBay |
#813 |
Here is how I built mine. I used a generic cheap metal box modified to the rear to fit the pcb. I built it with the THAT chips and the light bulbs but sans the LCD. I put connectors for my DMM for this job. I attach loop measurements with a behringer UCA 202 usb soundcard. The performance is primarily compromised by the soundcard. I'm making some thoughts to transplant it into the interface box, bypass its analog in/output and connect the chip directly to to the interface making it a stand alone device.
#814 |
Thanks Magic. I included the THAT parts and lamps in my component buy so I can go down that route.
I was confused by your first trace with the fundamental at -1.5dBFS. I realised there must be something wrong with my calibration because I can never get anything like that. Even -3dB produces serious clipping according to Time Record. Paragraph 1.5.2 Calibration of Soundcard Input Channels has never made sense to me. Step 3 says "Press the button 'Generate sine (400Hz)' and monitor the input level at bottom peak-meters..." When I do that, the peak-metres don't register anything. I've just left input calibration unchanged from the value resulting from the output calibration. If I set the Generator to -30dB (240mV) and use the 200mV scale on the soundcard interface I get -28.3dBFS. I'll have to learn how to use STEPS too. |
#815 |
I started from the same level as you about a year ago and still learning so, I can only describe what I've found hoping it will help. It seems you have digital clipping, you will know how ugly that is when you feed real music to your speakers under this condition. Anyway, you can go to your soundcard control panel and see if you can adjust line in levels - you should. Set out level to max and adjust input until you get the best results for calibration and measurements. To give you an example, in my soundcard, the input level slider has a range from 0 to 100 and I had to take it down to 3. Once you get the calibration right, STEPS is easy to use.
#816 | |
Jan
Linear Audio - Articles - SilentSwitcher - Treg hi-voltage regulator - Hi-voltage delay unit - AutoRanger |
#817 |
Jan: Does that mean the peak is caused by 50Hz noise in power supply? Or 50Hz noise in the ground loop caused by the way the device is powered?
Or perhaps induced into the tool from the outside? IMO the easiest way would be trying to power the tool from the soundcard itself. Power lines are easily available in Juli (pinout e.g. hifi.slovanet.sk :: Zobrazi? t?mu - Anal?gov? ?as? ESI Juli@ + I2S ) |
#818 | |
#819 |
Incorporating the soundcard into the box is a great idea. What voltage levels are you putting into the interface and what setting are you using? I suspect you're using higher levels than I am.
Attached are my best results with the standard ICs and shielded box. Best results are on the 2V scale. You'll noticed that the distortion results stop at 75.4Hz. This is a problem I'm having with STEPS: the sweep terminates after a random number of steps. I have to click "Stop" to regain control of the app. I posted a question on the ARTA thread but I still have the problem. |
#820 |
As already said I'm not a specialist myself but willing to help this is what I've done: PC interface set to 2V range, soundcard output level to max (100/100), input level quite low (2/100). But this setup may not apply to other soundcards. I found that working during the calibration procedure, where I suspect you may have done something wrong. Better try to calibrate without the PC interface in the test rig and follow the instructions to the letter. Remember to take AC measurements with your DMM and of course you will need to do calibration separately for STEPS. Also at steps check single channel level at measurement setup.
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Recommendations on pc audio interface for loudspeaker measurement | diypole | Multi-Way | 9 | 15th July 2009 01:45 PM |
Request for advice / high performance soundcard for measurement | Gordy | Solid State | 8 | 14th February 2008 05:14 PM |
MCM Speaker Measurement Interface / USB Woofer Tester | sdclc126 | Multi-Way | 0 | 17th January 2007 02:00 AM |
Tenma Speaker Measurement Interface | johngalt47 | Multi-Way | 1 | 6th January 2007 03:17 AM |
Soundcard interface. | Mr Evil | Everything Else | 5 | 13th July 2005 12:38 AM |
New To Site? | Need Help? |
