His Master's Noise: A Thoroughly Modern Tube Phono Preamp
Old 24th October 2010, 05:11 AM   #61
jackinnj is offline jackinnj  United States
jackinnj's Avatar
SY -- where did you park the shield lead from the Sowter 8055's.
Old 24th October 2010, 10:54 AM   #62
On Hiatus
SY's Avatar
On the first stage input ground.
edit: Scratch that, bad memory. On actually looking at it, it's returned to the chassis solder tag at the DIN input.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 24th October 2010, 09:42 PM   #63
volleynbike is offline volleynbike  United States
Here's a simple little improvement that i've had wonderful results with. Splice in a simple diode (1N4007 or similar) in between the screen grid of the pentode and the Plate with the cathode of the diode pointing toward the screen grid.
Easy to remove if you don't like it. But every pentode amplifier stage i've tried it in shows a marked improvement (extended range, lower dynamic compression, etc.) Admittedly i haven't tried it in such a low level stage as 1st phono, but worth a try...
I've been looking for new mc phono circuit to try, and i think this may be it! Nice job =)
Old 27th October 2010, 02:25 AM   #64
jackinnj's Avatar
Here's a comparison of the HMN to my Linn LK-1 which has a dedicated MC input:
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
Old 27th October 2010, 02:31 AM   #65
Pano is offline Pano  United States
Pano's Avatar
The HMN certainly looks a lot cleaner.
Old 27th October 2010, 01:26 PM   #66
jackinnj's Avatar
I will have some boards made as a Group Buy -- I'll absorb the cost of the first set of prototypes -- but I have to figure out all the mistakes I made on the first set. Price will be the manufacturing plus shipping to the US. I think it's going to work out to be something like $7.20 per board. The board will have provisioned the amplifier, hv supply, set of regulators (4x) and heater supplies.
Mistakes I made on my prototypes included spacing some of the mosfets a bit close, failing to include take off points for the heaters, building in only one set of HV regulators (SY recommends 2), using a 2A bridge rectifer for the heaters instead of 5A (seems to work fine, however). I'll provision it for various types of caps (Wima, Vishay, etc.) and make it a bit easier to tweak the R and C values for the RIAA equalization.
Old 1st November 2010, 10:54 PM   #67
studeb is offline studeb  United States
studeb's Avatar
Interested in boards.
Any feedback from the NJASDIYM?
Old 2nd November 2010, 12:36 PM   #68
jackinnj's Avatar
Yes, I am going to have some boards made -- it requires a bit of tweaking the original since SY specified 2 regulators -- one per channel. I am not going assume that folks will use transformers with wires rather than PCB pins.
I would think we'll have the boards in about 2 weeks.
I think I will have plenty of power supply boards since folks ask for these all the time, regardless of what they happen to be building!
Old 2nd November 2010, 03:21 PM   #69
On Hiatus
SY's Avatar
I haven't tried this with a single regulator, but if the pass device is well heatsinked, it should also work- the PSR of the circuit is really high and the current draw is exceptionally constant. Not to discourage you from laying it out as originally designed...
Old 12th November 2010, 02:14 AM   #70
Slobo is offline Slobo
Default Boards
I'm also interested in boards.
His Master's Noise: A Thoroughly Modern Tube Phono PreampHide this!Advertise here!
Low noise transistor and noise figure Real_Macgyver Solid State 28 27th July 2012 09:42 AM
noise planarboy Analogue Source 2 11th February 2008 08:06 AM
Still have noise. pjanda1 Chip Amps 40 17th March 2006 03:16 PM
Help with noise davidlzimmer Chip Amps 25 5th March 2006 09:39 PM
Noise Bukitoo Analogue Source 2 17th March 2004 02:37 PM
Copyright ©1999-2019 diyAudio
