His Master's Noise: A Thoroughly Modern Tube Phono Preamp
Thread Tools
Old 26th March 2021, 07:12 PM   #671
TasoTaso is offline TasoTaso
Originally Posted by tvicol View Post
Order your pcb at desired manufacturer. I have posted source files
here:
and power supply here
Gerber files are needed ones.
Tibi
hi, I would like to make your pcbs. Is this link correct for the latest versions? is there a list of components? thanks you are very kind to share!
Old 27th March 2021, 06:08 AM   #672
tvicol is offline tvicol  Europe
tvicol's Avatar
Here is latest power supply version His Master's Noise: A Thoroughly Modern Tube Phono Preamp
One partial BOM is here His Master's Noise: A Thoroughly Modern Tube Phono Preamp
A more exquisite one is here His Master's Noise: A Thoroughly Modern Tube Phono Preamp
Tibi
https://evotronix.eu
Old 27th March 2021, 01:47 PM   #673
ok, thanks.
Old 30th March 2021, 09:38 AM   #674
FJC Corpas is offline FJC Corpas  Spain
Originally Posted by jackinnj View Post
Here's a comparison of D3a's
jackinnj, I have built a jig to test the noise of several of my D3a's. My results are slightly worse than yours, I suspect because your Audio Precision is much better than my measurement equipment. However I have some questions:
- Did you measure the D3a's on the same HMV circuit or did you build one specifically for that task?
- I assume you measured the noise at the anode of the D3a, right?
  Reply to this post
His Master's Noise: A Thoroughly Modern Tube Phono PreampHide this!Advertise here!
Thread Tools
Low noise transistor and noise figure Real_Macgyver Solid State 28 27th July 2012 09:42 AM
noise planarboy Analogue Source 2 11th February 2008 08:06 AM
Still have noise. pjanda1 Chip Amps 40 17th March 2006 03:16 PM
Help with noise davidlzimmer Chip Amps 25 5th March 2006 09:39 PM
Noise Bukitoo Analogue Source 2 17th March 2004 02:37 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
