His Master's Noise: A Thoroughly Modern Tube Phono Preamp
Old 12th May 2020, 06:28 AM   #611
tvicol is online now tvicol  Europe
tvicol's Avatar
Default boards arrived !
Time to heat the iron !
Tibi
https://evotronix.eu
Old 12th May 2020, 10:30 AM   #612
Celsius is offline Celsius  Spain
Celsius's Avatar
Tibi
We can buy the pcb ?
Old 12th May 2020, 10:39 AM   #613
tvicol's Avatar
Order your pcb at desired manufacturer. I have posted source files
here:
and power supply here
Gerber files are needed ones.
Tibi
Old 12th May 2020, 10:45 AM   #614
Celsius's Avatar
here:
Tibi
thanks for your prompt reply.
Anyone want to order both pcb ??
Old 15th May 2020, 03:35 PM   #615
anystereo is offline anystereo  United States
Does anyone have PCB's in hand for the Voltage Regs and the low volt filament supplies?
David
His Master's Noise: A Thoroughly Modern Tube Phono PreampHide this!Advertise here!
Low noise transistor and noise figure Real_Macgyver Solid State 28 27th July 2012 09:42 AM
noise planarboy Analogue Source 2 11th February 2008 08:06 AM
Still have noise. pjanda1 Chip Amps 40 17th March 2006 03:16 PM
Help with noise davidlzimmer Chip Amps 25 5th March 2006 09:39 PM
Noise Bukitoo Analogue Source 2 17th March 2004 02:37 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
