His Master's Noise: A Thoroughly Modern Tube Phono Preamp
Old 14th December 2017, 03:34 PM   #471
lehmanhill is offline lehmanhill  United States
lehmanhill's Avatar
Originally Posted by jackinnj View Post
It depends on which clerk at the post office
So true.
Old 14th December 2017, 06:09 PM   #472
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Originally Posted by luis.martins View Post
Hi Jack,
Great to hear from you!
Are the boards just for the audio circuit?
Do you have a photo of the boards?
And maybe assembled board?
How did the tests turn out?
Luis
See this post, and those surrounding: His Master's Noise: A Thoroughly Modern Tube Phono Preamp
Old 17th December 2017, 11:45 AM   #473
frankwilker is offline frankwilker  Germany
i use a R-Core-Transformer.
Never a problem with hum. A good solution against hum is also to use the PS for tube heating which was provided from Allen Wright.
One adjustable LM317 for each tube. I works like a CSS against hum. If you are interested, mail me.
Old 17th December 2017, 12:11 PM   #474
Hi Luis,
to trim the RiAA you have to use the complete first stage, cause the Resistor (i think Ri) is part of the RIAA network. Read Sy´s explanation carefully. Its very helpful.
Myself i used measured and matched 10nf Mica East-Europe. My RIAA-network matched with 3 x 10nf Mica, 3,3 nf Wima FKP2 and 680 pf and 20,7K as R7.
If you are interested at the Mica, mail me, please.
Old 17th December 2017, 12:15 PM   #475
Old 17th December 2017, 12:20 PM   #476
Old 17th December 2017, 02:19 PM   #477
lehmanhill's Avatar
Mica caps are great, I find them very neutral. Did you do your own board? It looks like the board was made with the 3 parallel Mica + FKP2 designed into the board.
I love that you have space for the big axial caps too.
Jac
Old 20th December 2017, 10:24 AM   #478
Hi Jac,
the Micas are great. I made this board first for mounting in my Hovland HP100. As I developed the board, i made sure that there is place for different capacitors and for the Micas I owned. The best is, the most russian or east-european Micas have a tolerance from 0,5 to max 1 percent. Now is the hovland sold and i have to build a case for the noise-machine.
I build a second board (this is sold) so i bought 100pcs 10nf Micas (matched). Fortunately they match the place on the board.
If somebody is interested in Micas, please ask.
Old 3rd January 2018, 05:58 PM   #479
luis.martins is offline luis.martins  Portugal
Originally Posted by mrdave45 View Post
I would be tempted to use your dual caps so both sides work on 160v L + R and the other on 260v L + R. I think you'll find the overall layout of the boards in the case a bit easier.
Hi Dave,
Thank you for your tips!
I'll have to work on the layout of my build, but I guess it will be close to yours.
I'm planning on one box only, so there will be no cables with HV plugs.
Luis
Old 3rd January 2018, 06:05 PM   #480
Boards are $3.00 shipping to Portugal probably $9 or $12. It depends on which clerk at the post office
Hi Jack,
Thank you for your reply. for now I think I'll work on a point to point construction of the signal circuit, with the CCS on small breadboard style PCBs. It will give a bit more freedom in the layout.
I'm very keen on tube amps where the tubes pop out of the box and you can see the tubes glowing. I understand it is a very romantic idea, but I guess that is why we spin vinyl on our turntables to start with.
Luis
His Master's Noise: A Thoroughly Modern Tube Phono PreampHide this!Advertise here!
Low noise transistor and noise figure Real_Macgyver Solid State 28 27th July 2012 09:42 AM
noise planarboy Analogue Source 2 11th February 2008 08:06 AM
Still have noise. pjanda1 Chip Amps 40 17th March 2006 03:16 PM
Help with noise davidlzimmer Chip Amps 25 5th March 2006 09:39 PM
Noise Bukitoo Analogue Source 2 17th March 2004 02:37 PM
Copyright ©1999-2019 diyAudio
