His Master's Noise: A Thoroughly Modern Tube Phono Preamp
Old 30th May 2017, 10:52 PM   #361
mrdave45 is offline mrdave45  United Kingdom
Back to the hmn...
I'm struggling to find suitable connectors to get between the psu and phono stage.
I obviously want to make sure that the psu can't have exposed pins with HT on them if not connected.
I did find a 5 pole connector that looked OK but as it had a plastic body I couldn't connect protective earth through that. At least that's what it looks like sy did in the pictures.
The 6 pole version isn't stocked any more.
I don't know how I feel about having a 5 pole cord and then a totally separate earth bond wire connected by screw down binding posts. I would use the crimp type connector that looks like an earth tag that goes over the bolt that gets screwed down so it can only come off it the nut comes completely off too.
Old 31st May 2017, 02:48 AM   #362
kevinkr's Avatar
Take a look at the line of CPC connectors at digikey or mouser. I use these up to 400V or so without problems.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 31st May 2017, 10:41 AM   #363
Do you run protective earth through them?
Old 31st May 2017, 12:43 PM   #364
lehmanhill is offline lehmanhill  United States
lehmanhill's Avatar
I ran an 18 gauge stranded through plastic connectors between my separate psu and phono stage on my EO phono stage build. I know that 18 gauge doesn't sound that big in the event of a failure, but it will pass 16 Amps which should be enough to blow the fuse in the event of a failure. 600 V wire, of course.
I agree with kevinkr, there a lots of connector options at digikey, mouser, etc. A lot of the industrial connectors are good for high voltage and reasonably priced.
Old 1st June 2017, 02:48 PM   #365
cheers. In the end i got an ampehnol c16 3 which is really strudy and the female contacts are well recessed with a dedicated protected earth contact which is more prominent so it would lose contact last.
Ended up getting some 7 core rather than 6 core wire. Could find anything suitable that they would sell per meter. I really dont need a reel of it! 16awg and fits the amphenol and the gland on the other end perfectly.
A bit more than i wanted to spend but this is definitely not going to fall apart or get tugged out leaving either one chassis ungrounded or 300+volts on a pin!
Cheers
Old 1st June 2017, 02:59 PM   #366
My next question is about strip board/perf board. I need to construct the HT supply and HT regs old school.
What do people find best/easiest?
1. perf board, which i think it just single pads that you solder connecting wires along,
2. Strip/Varioboard.
3. Groups of three padboard. I usually find myself wishing these were in strips of 4 or 5 holes.
Ive built a few things on strip and groups of three but usually takes a while (more than a while sometimes) to work out how to lay it out.
Do i also need to worry about high voltages on these things? I cant find any voltage ratings on the datasheets.
I did find some nice strip board in maplin a while back which was fibreglass rather than the cardboardy orange stuff and tinned strips.
Old 1st June 2017, 06:01 PM   #367
lehmanhill's Avatar
I used some group of 5 padboard that I found at Mouser or Farnell. You can see a picture of it in post 223 of the Equal Opportunity MM Pre thread. The regulators are on another of the same board. Happily, the EO doesn't use quite as high a voltage as the HMN, but I was probably pushing it because the gap between pads isn't that big. I did manage to keep unconnected pads between high voltage and ground on the high voltage circuits.
Given the high voltages in the HMN, I might be tempted to use perf board and high voltage insulated wire from point to point.
Jac
Old 2nd June 2017, 12:01 PM   #368
there was a post recently regarding heater voltages. I think more to do with the equal opportunity amp but i want to just check Ive understood correctly.
For the HMN,
One output board will have the heaters connected to 65v and 71.3v giving a diff of 6.3v
and the other output board would have 65v and 58.7v also giving a difference of 6.3v
Presumably the positive 6.3v and negative 6.3v is because thats an easy way to elevate the voltage using the transformer.
If i tried to use 65v+/-3.15 V then they would be floating and i would also have major problems trying to stop my regulators overheating.
Does it matter which pin (4 or 5) gets the 65v?
Im assuming not but for my OCD I sort of want
Board A
pin 5 71.3v
pin 4 65v
Board B
pin 5 65v
pin4 58.7v
Old 2nd June 2017, 02:13 PM   #369
Ive also noticed that the pcbs i have specify C5 and C4 as X2 rated.
Ive had a look at the impasse schematics and boards and there are caps doing the same job under more stress but no mention of X2 ratings in these cases. Do they actually need to be X2 or are the standard wima mkp ok?
I managed to order 1uF 250v by mistake for C5 (just to add to a stack of 1uF 250v mks4s i already had!), i appreciate that this probably does need to be 400v as until the HV regs stabilise there could be more than 250v across it.
I do have some 2.2uF 400v MKP4 and some 0.68uF and 0.33uF 600v multicaps. But tbh the 0.68 is a bit on the large side for the board.
Would either of these do or does it really need to be 1uF?
Old 2nd June 2017, 04:40 PM   #370
peafarmer is offline peafarmer  United States
I imagine that the schematic you are looking at assumes that a "line" rated capacitor will be used. I know that the F5 power supply specifies it explicitly.
His Master's Noise: A Thoroughly Modern Tube Phono PreampHide this!Advertise here!
Low noise transistor and noise figure Real_Macgyver Solid State 28 27th July 2012 09:42 AM
noise planarboy Analogue Source 2 11th February 2008 08:06 AM
Still have noise. pjanda1 Chip Amps 40 17th March 2006 03:16 PM
Help with noise davidlzimmer Chip Amps 25 5th March 2006 09:39 PM
Noise Bukitoo Analogue Source 2 17th March 2004 02:37 PM
Copyright ©1999-2019 diyAudio
