Nothing change !
I have spent alot of studies for the past months
And now enjoying the results and taking my time also enjoying my new bluray for the past few days!.
Its just pictures. Colors and contrast are much better in actual. White level is very pleasing
and black is solid.
and black is solid.
New project : 7 inch 1280x800 N070ICG IPS panel contrast:800 response time: 12 ms
My test bed.
Initial shots. This is a bad shot.. Will post good shots later.
evaluation. Using 128w led
The good:
1. The throw distance is 13 ft to fill my 120 inch screen. There is no keystone problem at this distance and the image is perfectly square.
2. Better shadow detail .
3. Better brightness at the sides, which helps me perceived that there is more details at the sides.
4. Better response time. Smoother image when image i spanning across the screen.
The bad or not so bad as compared to B101EW05
1. The B101EW05 white is sparkling while N070ICG white level is tamed, but in a very bright daylight scene, N070ICG gives better detail. The B101EW05 white is just so attractive.
2. The N070ICG skin tine looks natural but B101EW05 skin tone is more pleasing because of its more vivid colors .
3. Black level is decent compared to B101EW05
4. Of course the B101EW05 is better in terms of resolution at same image size, but N070ICG resolution is still very nice at 120 inches. Superior than Innolux svga. In many scenes, there is no perceived difference with B101EW05.
Will post better pics later.
My test bed.
The good:
Start here they are all the same. nothing special except the lcd.
http://www.diyaudio.com/forums/diy-projectors/33356-diy-projector-philippines-74.html
- General Interest
- Everything Else
- The Moving Image
- DIY Projectors
- diy projector from the Philippines
