How to get your beloved CD-player from the eighties into the Digital Domain
Administrator
Joined 2004
Hi Salar,
The Nak machines use the Philips chip set. My thoughts at the moment are to run a buffered eyey pattern into another servo board and let it fully process the signal and provide the required outputs.
The early Philips chip set is ugly to work with.
-Chris
CXD 1125Q have some extra features other than DOTX. I believe it can be set/disabled with some pins I/O (or, worse case scenario, controller settings).
The CXD1125 outputs 2FS
CXD1125, pin 56 "H", 57 "L", 2FS;
pin 56 "L", 57 "H", 1FS.
(CXD1135 too!)
also can take a look on the thread (some delay added)
  • cx23035_1.pdf
  • cx23035_2.pdf
