Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
non os measurement
non os measurement
Thread Tools
Old 13th September 2006, 12:31 AM   #1
Bernhard is offline Bernhard  Germany
Bernhard's Avatar
Default non os measurement
This is about a partially filtered non os DAC.
First, music signal from an oversampling CD player, 31 kHz analyzer bandwith.
It can be seen the CD bandwith limitation of 22,5 kHz.
non os measurement
Now the transformer + cap filtered non os DAC.
The empty space above 22,5 kHz is filled with harmonics.
Non os gives back a little of what the CD format has taken away.
non os measurement
Pink noise from CD with oversampling, 83 kHz analyzer bandwith.
non os measurement
Pink noise from CD with non os DAC.
It can be seen, at 80 kHz HF is pretty much down.
That should not be a problem for a good amplifier.
non os measurement
Old 13th September 2006, 01:50 AM   #2
Bernhard's Avatar
1 kHz full scale sine non os.
There is the rest of the HF visible.
non os measurement
FFT of the sine, analyzer bandwith 10 kHz, 94dB vertical scale.
The k2 harmonic is caused by the passive I/V.
non os measurement
Same with 100 kHz analyzer bandwith, the 44,1kHz and 88,2 kHz are split, jitter
non os measurement
Old 13th September 2006, 07:24 AM   #3
Werner is offline Werner  Europe
These aren't harmonics, and thus these aren't what 'the CD format has taken away'.
Baseband frequency f creates images at every N*fs+f and N*Fs-f,
so 1kHz has images at
44.1kHz-1kHz
44.1kHz+1kHz
88.2kHz-1kHz
88.2kHz+1kHz
Old 13th September 2006, 10:12 PM   #4
Bernhard's Avatar
44.1kHz-1kHz
44.1kHz+1kHz
88.2kHz-1kHz
88.2kHz+1kHz
Still, there is something above 22 kHz and maybe it makes a difference. Perhaps.
  Reply to this post
non os measurementHide this!Advertise here!
Thread Tools
PC Dac Measurement supra Digital Line Level 1 14th July 2009 01:54 PM
hum measurement Gluca Tubes / Valves 10 18th May 2005 11:26 AM
how to take db measurement sonu Multi-Way 7 9th May 2005 04:03 PM
New measurement mic in UK pinkmouse Multi-Way 4 10th February 2005 06:46 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
