Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
FIR Digital Filter
FIR Digital Filter
Old 26th February 2006, 03:51 AM   #21
tmblack is offline tmblack  United Kingdom
Its very easy to compute a FIR LPF up to half the sampling frequency.
Then convolve the filter coeff. with NOS signal.
Tom
EE
Old 26th February 2006, 06:46 AM   #22
rfbrw is offline rfbrw
Back to PatPet. So you want to build a standard oversampling digital filter with the exception that the summing of the taps is done externally.
As an example I'll use the first stage of the SM5847. The first stage is a 2x filter. It has 169 taps. You could fold the filter but that would be cheating, so 338 dacs it is. And then there is the physical implementation of the filter. Still think this is a viable idea ?
17.4 million lemmings can't be wrong.
Old 26th February 2006, 06:58 AM   #23
PatPet is offline PatPet  Hong Kong
For this number of taps, I barely think the impulse response will look good.
But I tried some FIR filter designers and found anything more than 3 taps will start resulting in pre-echo and post echo, which I think is no good at all. And for 3 taps we get 4x OS.
Maybe after that I play with linear interpolation and get more staircases on a 4X waveform. And hopefully the ultrasonics decay much faster.
And with 3 taps, the digital filter wont have good specs. But I'll trade something for good impulse response.
DSP Digital Filter anyone?
Old 26th February 2006, 10:41 AM   #24
4real is offline 4real  Netherlands
Sure it's easy, but what is the point in doing this? It won't even be a lowpass, since you don't have any audio data after 1/2 x fs anyway
Who sais it's audible? And in what freuquency range? With three tabs, I don't think you'll have an acceptable passband ripple. No way that's going to sound any good. You'll also need a speed enough stopband of course. The ringing will occur arround the crossover freqeuncy, and therefore with oversampling, you'll not hear any of it.
Effectively, the FIR filter will do the non linear interpolation for you
Just forget it, it's no good.
Old 26th February 2006, 12:11 PM   #25
Impulse Response
I think one of the offenders in OS is the pre-echo in the time domain and the other is jitter sensitivity.
I start digging myself into IIRs. Post echo is less offensive.
Old 26th February 2006, 12:46 PM   #26
That's why the crossover is at such a high freqency where you don't hear it anyway. If you think it is audible, point me to a single decent oversamping DAC that has this problem. Good luck!
Yes, but they are not phase linear, specially if you want a brick wall filter. Besides, there is still no use of such a filter if you don't oversample!
So explain exactly what do you intend to do with such a filter?
Old 26th February 2006, 01:37 PM   #27
Okay I will answer this later. For the time being I find this quite interesting
http://www.mlssa.com/pdf/Upsampling-theory-rev-2.pdf
Old 26th February 2006, 01:51 PM   #28
Upsampling != oversampling, the fact that the article does not seem to know the difference is not really good.
I will never claim that upsampling would have any positive effect on sound, oversampling just makes stuff a bit easyer. But the filtering just won't work with a non oversampling DAC, not FIR, not IIR.
Old 26th February 2006, 09:19 PM   #29
No you have multifple images up to fs and beyond.
Maybe you should take a course or 2 in DSP.
Tom
EE
Old 27th February 2006, 08:06 AM   #30
tubee is offline tubee  Netherlands
tubee's Avatar
one could just build a filter using many DACs being fed digital signals with appropriate delays applied to the inputs.
I am that "one" at this moment, with 4 dacs. But Wadia and an other UK manufacturer used it also a long time ago.
And select difering sized summing resistors to create the tap weighting
Wa2ise, what do you exactly mean with this?
Daisy Bell
FIR Digital FilterHide this!Advertise here!
Which digital filter to use ? jean-paul Digital Source 18 28th November 2010 09:24 AM
FIR Digital Filter DSP neededandwanted Parts 1 9th April 2009 02:44 AM
Digital (DSP) filter magnus Digital Source 12 9th February 2003 01:17 PM
Copyright ©1999-2019 diyAudio
