I've been reading this forum to learn more about DACs for about a month now ..
i have never built a dac by myself, nor have i ever built anything from scracth in audio electronics ...
The complexity of DAC circuitry/requirements doesn't stop to amaze me, and i thought that it was pretty much simple, feed some signal, power up the chip, output stage et voila! ( well i guess that nothing is ever that simple in electricity when you want performance )
We have seen many many examples of diy DACs using older chips, OS and non OS , a few using more recent chips like the pcm179X ... all seemed to require some extensive time to design and implement properly,
and i guess that most of the advanced user on this forum have helped out everybody to sort all bugs and things out wich led to nice results, am i right?
My question now is, was it all really worth it?
Taking this question in the point of view of performance,
and not for fun and challenge of designing/building something from scratch ( or from other's base )
Have you guys ever compared the performance of your DIY DACs VS the performance of available commercial kits?
When i first started to research this section of DIY
for DACs, i thought that a small board with only 2-3 main chips and a few resistors couldn't be that costy ..probably always sub 100$ for all components, that would've been for a ultra high quality DAC
( since i had seen that most DAC chips sells for 10$ and less each )
But i've seen some people around here and from outside links selling DIY kits for a few 100$ , wich pretty much closes up to commercial products in used form.
( and that was for older designs using older chips ,
i have yet to see a complete kit using the pcm179X for a reasonnable price <~200$, and i personally cannot settle for something less than the best/newer chips in those price range )
So taking apart the desing challenge, and diy community pleasure , is it really worth it to invest time on a diy DAC ?? ( again performance wise )
I'd like to see comparisons of price VS performance
of commercial and DIY type of DACs ... i haven't looked much into commercial since i wanted to keep the cost of my projects low , but since there is a lack of what i am looking for around here ( and i don't quite trust anywhere else for good reasons ) i might just consider getting some good used commercial stuff
( unfortunatly...again )
I have to say that i completly lack the skills necessary to design anything DAC wise, or even think about designing it .. this might affect my point of view i guess ..
What do YOU think ?
Shouldn't we all be working on a single recent ultra high performance design with options and possibilities, using the best chips available ?
that would be pretty cool ! i'd be the first in line to shell out some $$$ investing into this .. neway
i hope that there is a point to all what i just typed
Pleae prove me wrong ! !! ahahah
What do YOU think ?
Ultimately, the quality of a piece of audio hardware lies with the person who designed it. If they've got good design skills - layout, grounding, power, good component selection, etc - then they can create a piece of equipment with outstanding performance.
Wether this person designed the equipment at work (commercial) or designed it in their own time (DIY) is irrelevant, really. I've seen plenty of bad commercial equipment, and plenty of great DIY equipment. I've also seen lots of bad DIY.
So... *shrug*
So... *shrug*
Thanks for the quick reply "G "
Well that is what i thought also ...
but i have failed to see any diy dac that falls into what idescribed ( except for your's ... wich i believe is not quite available ?? )
Have you received my email BTW ?
I'd like to chat with you , If you have some spare time, i'd need some help based on your work !
contact me at: jin at intermonde dot net
How does your DAC sounds ? have you measured it ?
What is your TOTAL cost for your DAC/amplifier ?
( only the DAC sectionn if you can sum it up like that )
Are you satisfied with its performance ?
You probably have the only pcm179x diy with a reasonnable price range ..
How long was it to designed the DAC section of your kit ? have you based it on other's work or starter from scratch ?
Hi JinMTVT,
One thing to consider in any design is that the "best" way to accomplish something is always an opinion. There is more than one way to skin a cat so to speak. I've seen many good DACs, all different.
Another point to consider is that a designer may put together a great DAC, but a poor audio buffer or power supply. Some don't even believe in a buffer (it's in the chip then hopefully).
Getting a properly designed commercial board is important, so even if the cost compares to a commercial unit, I feel the chances of getting a superior unit are excellent. The workmanship is on your shoulders.
Finally, there is flexibility. You can redesign and implement different power supplies and buffers yourself. You now have the flexibility to do so.
-Chris
-Chris
Just my two cents.
I built 4 DAC's over the years. Recently, I compared my Tube DAC with a TEAC Esoteric DV-50 (cost U$5500). The DV-50 is the best player I heard so far, music full of air, sweetness and delicacy, great timing, etc. This was with regular CD and oversampling.
Using the DV50 as transport, my Tube DAC gave me I would say, about 80% of the DV50 sound. It sounds just great. My Tube DAC can greatly improve the sound of my other CD players and cost a fraction of the TEAC.
Great DAC's are worth it
Bye...
Bye...
This is the lowest price I've seen so far for Benchmark DAC: http://cls.audiogon.com/cgi-bin/cls.pl?dgtlconv&1137968841
Some people are really desperate to get rid of commercial, Stereophile class A rated product. I had one too.
I still keep ML360S, which is $7500 DAC. However, for the last 3 months I've been continuosly listening to home made NOS DAC, and haven't the slightest desire to plug the Levinson in.
Peter Daniel said:This is the lowest price I've seen so far for Benchmark DAC: .... I had one too.
And.....? Curious what you thought. I have one (don't worry, I have no emotional attachment to hardware, fire away) which fortunately was purchased at cost via industry connections. Later I learned that for some incomprehensible reason Benchmark set the unbalanced output impedance to 1.8 kohm, fixed in later production.
But like I said, no emotional attachment. Its form factor is convenient for having a headphone out and volume pot though. I'ld appreciate hearing your opinion on the differences in tonal balance, space, etc., between it and your DAC.
I've done the approach of modifying an older existing CD player with tubes. See my web site http://pw2.netcom.com/~wa2ise/radios/tubedac.htm#tubedac
Older CD players like the ones I've used can be had on ebay. A web site http://www.freeweb.hu/mestertuning/dac.php can tell you what DAC is in various older CD players, so that should help you find a machine with a desired DAC chip. What I've wanted in a DAC chip is a current source from an R2R ladder without any attached inside the chip op-amps.
I posted some comments about Benchmark here: http://www.diyaudio.com/forums/showthread.php?s=&postid=691879&highlight=#post691879
By now I already forgot how it sounded
The info about the DAC can be found in May Latest News section, on my site.
Its all-in-one nature eliminates a lot of variables, the consistency making it a great little tool for for voicing amps. Still good to know where other ears place it. Thx again for the 6 Moons tips, I'll check it out. I have popped the top but, seeing a sea of SMD, went no further.
- Digital Source
- DIY DACs VS Commercial stuff .. really worth it?
