Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Best R2R dac chip?
Best R2R dac chip?
Thread Tools
Old 29th January 2005, 12:28 PM   #11
ThorstenL is offline ThorstenL  Germany
Previously: Kuei Yang Wang
Default Re: Best R2R dac chip?
Konnichiwa,
Originally posted by Kip
My choice is an R2R dac with no-oversampling, no receiver and enough output to elimiate any I/V stage.
There is not really any such device. From experience the best sounding R2R DAC is PCM63, the one closest to your requirements is however the PCM56 which will tolerate up to 1K I/V Resistor and therefor will output up to 1V Peak with passive I/V conversion.
The TDA1541, 1543 & 1545 are not R2R DAC's. I fail to understand why you insist on R2R devices? You exclude the very DAC's you should be looking at most.
The TDA1541 is IMHO the best sounding DAC for CD replay FULL STOP. It MUST have a well designed analog stage.
The TDA1545 sounds a lot like a 1541, but not quite as good, most of the 1541's limitations apply and the generally 1545A uses EIAJ input format.
The TDA1543 sounds okay, but hardly great (compared to others and again IMHO) but it can give nearly full CD Standard output with a passive output stage, can run easily of batteries and is dirt cheap.
For your use and given your skills level building something with multiple TDA1543 in parallel is likely the better choice.
Sayonara
Old 29th January 2005, 12:44 PM   #12
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Default Re: Re: Best R2R dac chip?
You said this on more than one occasion but despite being not full R2R DAC chips they can be grouped under "non-1bit" classical bipolar ( except 1545a which is CMOS ) DAC chips. They are more R2R than any 1 bit DAC chip anyway
It's only audio. Member of the non modular PCB design committee
Old 29th January 2005, 01:07 PM   #13
Default Re: Re: Re: Best R2R dac chip?
Konnichiwa,
Yes, they are "multibit" Chips, however their operation internally drastically differs from R2R Architectures, by using a mixture of active switched current sources for the lower bits and multiemitter transistor current dividers for the upper bits. The operation methodes between R2R and the Philips devices could not be more different.
Sayonara
Old 29th January 2005, 05:24 PM   #14
Guido Tent is offline Guido Tent  Netherlands
Originally posted by jwb
Oh, I see. A resistor is an I/V converter, just a really, really simple (and bad) one.
NO, it is one of the best available. Also in traditional I/V converters (the opamp based ones) the resistor is crucial (among the opamp).
The fact that they don't perfom well in the passive solution, is because they are not driven by infinite impedance, in the case of for example a PCM63 (estimated 1 k-ohm).
Don't blame the resistor............
cheers
Guido Tent
www.Tentlabs.com
Old 6th February 2005, 05:39 PM   #15
Kip is offline Kip  United States
Well, I am not sure again. I do have some PCM63 around. All comments are great. Do I lean toward the Philips or Burr Brown?
Old 30th August 2013, 09:24 AM   #16
crispy98007 is offline crispy98007  United States
Best R2R dac chip?
Default Burr Brown PCM 1704/Esoteric D-01 - R-2R A/D vs. D/A converter
Originally Posted by Kip View Post
I have finished a CD-PRO2M kit and would like to incorporate an internal dac. I have read on this site as well as searches on the internet about dacs. The PRO2M will output I2S and EIAJ. I2S is the default and EIAJ would require a software change. Most of my research has been on the TDA1541, TDA1543 and TDA1545a. The TDA1545a requires the EIAJ format. Today I was looking at Burr Brown PCM1704 and I do have two (somewhere) PCM63s. I also have an AD1865n. My choice is an R2R dac with no-oversampling, no receiver and enough output to elimiate any I/V stage. I would really like to be able to run balanced outputs. I am open to all suggestions, but would like to keep it as simple as possible. I realize no-oversampling does produce much noise above 22khz, so oversampling could be ok, but direct I2S or EIAJ. I am also open to a solid state I/V stage.
Hi all, it's been ages since I've been here, but I'm trying to do in reverse what I have here, and this is a shot in the dark. I realize this post is very old, but those chips are still made today and maybe someone is following this thread who knows the answer.
I own 2 Esoteric D-01 DACs which use multiple PCM 1704s, which are R-2R converters. The Esoterics are the best DACs ever made, in my opinion, at least I've never heard anything better to my ears and I've been in the hifi business for 35 years.
I'm looking for the same thing in reverse. I realize there's lots of engineers out there, but I'm looking for a product. The best sounding R-2R ANALOG TO DIGITAL (not digital to analog) converters. Everything seems to be based on Delta-Sigma chips, which I've heard in DACs but not ADCs so I can't say for sure, but I do know I don't like Delta-Sigma DACs.
DOES ANYONE MAKE A VERY HIGH END A/D CONVERTER USING R-2R CHIPS? Either 2 channel, multichannel, whatever? And who makes it?
I read it's possible on another forum, but either no really good product manufacturer makes one it or they're being smart-*****. The only thing I've found is on Wikipedia, but it doesn't say much:
Resistor ladder - Wikipedia, the free encyclopedia
Anyone's knowledgeable input is deeply appreciated. I seem to be going around in circles on Google. Thank you!
Old 2nd September 2013, 07:43 AM   #17
georgehifi is offline georgehifi  Australia
georgehifi's Avatar
Send a message via MSN to georgehifi
I don't know about very hi end as I have not heard them, but my fav is the PCM1704/K
http://www.audio-gd.com/Master/Master-7/M7EN.htm
http://www.audio-gd.com/Pro/dac/RE5.2/RE5.2EN.htm
http://www.audio-gd.com/Pro/Headphon...e10/RE10EN.htm
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 2nd September 2013, 11:13 AM   #18
merlin el mago is offline merlin el mago  Europe
Sin Bin
ºÍ§Ó*µ响
ºÍ§Ó*µ响
ºÍ§Ó*µ响
Cheers George
Mine too
Old 2nd September 2013, 12:37 PM   #19
Calvin is offline Calvin  Germany
Calvin's Avatar
Now I have to get the popcorn out.
Will be deadly interesting to see how You guys build a ADC from PCM1704 DAC chips
jauu
Calvin
My Website
Old 2nd September 2013, 03:14 PM   #20
Sin Bin
You are right PCM1704 is DAC not ADC
Best R2R dac chip?Hide this!Advertise here!
Thread Tools
Which Chip AMP you like most? dynabok Chip Amps 154 12th December 2012 02:23 PM
Pre-amp for chip amp wotsascott Chip Amps 23 30th April 2006 05:24 PM
First Chip Amp doomsweek Chip Amps 9 10th May 2005 02:55 AM
Best possible 10W from chip amp Robert_66 Chip Amps 14 2nd November 2004 12:43 PM
Hot chip! batkey Chip Amps 1 14th October 2004 12:54 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
