Bas, do you have 1-2 extra 1794 you'd want to sell? They've never been available as samples, and I'd hate to order from Digikey for just this item.
Have you already designed a PCB? I have made a .brd file for AD1854 with an on board ECL master clock that I can send you. The design can be changed to PCM1974 quite easily, just exchange a couple of connections, leave out the I/V convertors and drop in another regulator.
Eric
Eric
Hallo Eric,
I'm sorry I "misled"...you
I got the RAKK DAC kit...
Have not listened to it yet...can you believe it? Battery psu.
Don't have cd player at the moment. (Might try my dvd player tonight)
Bas
Bas
digi01 said:thanks for sky0841 share his projects,this is the dac sch file.pdf version.
the dac based on the cs8414 and pcm1798 chips,use class a power supply.audio grade parts.the sound is fine,clear and nature.
Bas Horneman said:It seems to me..that the PDF has been censored by the Chinese Government...because it is empty?
Bas
converted with xpdf & ps2pdf now it should work ...
Jobstens
BTW, your DAC looks really damn good. I really want to make use of these PCM1716's I have here. Where does one purchase a RAKK DAC kit? This DAC kit seems to be very very cool to assemble and use, but a full kit at $245USD is out of my spending range, despite how cheap it is. I am still happy with the DAC I built designed by jwb. I love that damn thing.
digi01, please get in contact with me. Your email doesn't seems to be working.
(The thing I wanted to tell you was to fix your code for the Gainclone webring The ring itself is here)
does anyone have info on where to buy the boards for the 1798 DAC pictured above?
The silkscreen says - www.ngtop.com, that is all in chinese so no help to me...
Any info appreciated!
- Digital Source
- my PCM1798DAC!!!
