Philips CD 160 convert to NOS
Joined 2016
Got one of these little gems at the moment. Want to try NOS mode. It is the model with the separate logic board. I’ve followed the usual instructions for converting to NOS but I must be missing a trick and I suspect it’s to do with the logic board?
- pull the SAA7220 (or cut its power and leave in situ)
- connect pins 1,2,3 on SAA direct to pins 1,2,3 on TDA1541 (or jumper them across the SAA to pins 18,16,15 (respectively)
