Try to seperate power lines (star connection for ground and 5v) for all circuits including servo's.
Lampie519 Member Joined 2006 2023-01-28 7:27 am #61 2023-01-28 7:27 am #61 Try to seperate power lines (star connection for ground and 5v) for all circuits including servo's. Reactions: 1 user ••• More options Share T thirteeneast Member Joined 2020 2023-01-28 12:04 pm #62 2023-01-28 12:04 pm #62 Hi Frank, Many thanks for your reply, So even if I add the toriodial the earths can be common to the existing supply? ••• More options Share Lampie519 Member Joined 2006 2023-01-28 2:49 pm #63 2023-01-28 2:49 pm #63 You will have to use ground somewhere or it wil be floating with unexpected results (in general bad). Reactions: 1 user ••• More options Share T thirteeneast Member Joined 2020 2023-02-01 10:11 pm #64 2023-02-01 10:11 pm #64 Well got everything done and tested on the bench and finally installed today. Done some listening tests and am very happy. Many thanks. I'll be sure to take some photos and upload soon. Reactions: 1 user ••• More options Share T thirteeneast Member Joined 2020 2023-02-03 4:37 pm #65 2023-02-03 4:37 pm #65 Reactions: 1 user ••• More options Share T thirteeneast Member Joined 2020 2023-02-03 4:38 pm #66 2023-02-03 4:38 pm #66 Reactions: 1 user ••• More options Share T thirteeneast Member Joined 2020 2023-02-03 4:43 pm #67 2023-02-03 4:43 pm #67 ••• More options Share B Boston460 Member Joined 2023 2023-02-05 2:25 am #68 2023-02-05 2:25 am #68 Looks good, may I ask what value film capacitors you used on the output of the op-amps? Thanks, ••• More options Share Lampie519 Member Joined 2006 2023-02-05 12:10 pm #69 2023-02-05 12:10 pm #69 And why are there still output caps ? These are not required if you build a servo as in the Marantz cd80. ••• More options Share Prev 1 2 3 4 First Prev 4 of 4 Go to page Go Show hidden low quality content You must log in or register to reply here. Share: Facebook Twitter Reddit Pinterest Tumblr WhatsApp Email Share Link Home Source & Line Digital Source Marantz CD273 Top Bottom
