Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
VFD Board of a Philips CD 320
VFD Board of a Philips CD 320 Please consider donating to help us continue to serve you.
Old 8th February 2020, 02:13 PM   #1
enryfox is offline enryfox
Default VFD Board of a Philips CD 320
Recently I got this player for cheap and I open it up to clean it and study it. The player works quite well and the CDM4 is still a quite reliable laser pickup.
I noticed, though, an odd circuit design for VFD driver board (refer to the schematics). V-FTD on the lower left side is 33 Volt (generated in the PSU by a 15V regulator with a 18V zener diode on its reference connection); that voltage is fed to the VSS pin of the IC driver but the nearby VDD pin requires only 18V. That level is obtained with a 15V zener diode (6971), which drops the voltage from 33 to 18V, and two 1.8 kOhm resistors (3971 & 3972) which keep a constant current flow through the diode. The problem is that each resistor is traversed by a 10 mA current and thus dissipates 180 mW; under normal use, the two resistors get pretty hot and the result can be seen in the second picture. The two resistors are quite tiny and I guess they are capable of handling only 0.25 W; moreover this CD player has a power switch that actually just cuts some voltages to make it appear it is turned off, but indeed most of the circuits are still powered. In the VFD board, only the AC power to drive the VFD is cut, all the other voltages (including V-FTD) are still on. So basically those two poor resistors are kept hot close to their max power handling spec for years and years !
To mitigate the issue I tried with two 4.7 kOhm resistors, but the zener does not reach the target voltage of 15 V and the 18 V reference voltage increases to 26V keeping the display off. I though 8mA would be enough for the diode but indeed it appears it needs 20 mA, so I placed again two 1.8 kOhm resistors but this time opting for 0.5 W resistors. They still gets warm but at least they should be more capable of handling 180mW of dissipated power.
In the end .. what the heck Philips ? what is the point of toasting the PCB with two tiny resistors ??!?!?.
Old 8th February 2020, 06:57 PM   #2
ubergeeknz is offline ubergeeknz  New Zealand
If there's the space, I'd suggest stepping them off the board.
The fact they survived indicates they were fit for purpose VFD Board of a Philips CD 320 the board going a little black isn't uncommon for power supply resistors in gear from that era.
Old 9th February 2020, 12:26 PM   #3
No room to offset the resistors from the board and the copper traces are pretty weak: out of four pads, three disintegrated while desoldering. The new resistors are actually big enough to better dissipate the heat
But why not use a real switch on the mains to really shut down the player when off ? Why keeping basically 80% of the circuitry constantly powered on ?
Old 9th February 2020, 12:34 PM   #4
MAAC0 is offline MAAC0  Portugal
You can always offset them on the copper side of the board.
That would perhaps help for preventing that black "fume" that coats the plastic window over the years.
VFD Board of a Philips CD 320Hide this!Advertise here!
FS Philips TDA1541A DAC Board Ruach Swap Meet 2 20th June 2013 10:46 AM
WTB: audio board for philips 963sa optimationman Swap Meet 0 29th August 2010 07:21 PM
Board pulled from Philips 5.1 channel amplifier maurycy Swap Meet 1 2nd February 2010 07:36 PM
Free Philips CDM4 Controller board happycat Swap Meet 3 9th March 2009 09:05 AM
Wanted: Philips CD 304 display board Richard Swap Meet 0 1st September 2006 08:23 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
