Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Highly modified Cambridge Audio CXUHD
Old 31st December 2019, 09:24 PM   #1
astro888 is offline astro888
Default Highly modified Cambridge Audio CXUHD
Hi. I though i would share my upgrade project that is finally finished.
I have taken a Cambridge Audio CXUHD player and done some serious mods.
I have taken the swiched psu and replaced it with a linear one. I didn't like the toridal transformer that came with it. So i replaced it with a custom one from Canterbury Windings that has been custom built for audio, with shielding between primary and secondary windings and also has a Metal Goss band aroud it for EMI shielding. I then got hold of a kit that i installed of milled aluminium that stabelise the optical drive. Further on i installed a second small psu from Lascar. And removed the voltage regulator, replaced it with a UWB 2 15.0V Ultra Wideband Low Noise Regulator from NewClassD. This was for driving the precision clocks i was going to install. I then removed two onboard oscillators with a heat gun. And removed some surface mount resistors and caps. That was a pain i n the ***, they where like 0.5mm so it what not so easy. I then precision solderd in small 50ohms coaxial cables with precrimped contacts for clock circuits where the oscillators had been. And because of the tension of the cable on the small connections on the circuit board i reinforced the soldering points with epoxi. So it should hold. I then connected two Neutrino 2 Reference clocks that has an accuracy of +/- 1ppm to the main board and to the modified Lascar mini psu. I then installed a mini switch to turn of the clocks when the player is in standby mode because the mini psu like the big one is always on. Unless you disconnect the mains cable. Finally i installed anti vibration Sorbothane feet im also planning to install anti vibration and stabilisation sheets to the chassis. but im quite pleased with the mods. They make an already good player get super! im planning to use it as bluray player but also a transport for my Simaudio Moon DAC. I would share this in case someone wants to mod their own CXUHD.
Highly modified Cambridge Audio CXUHDHide this!Advertise here!
modified truck audio system Audee Everything Else 0 18th April 2017 04:01 AM
Audio Research SP-3-A-1 modified......... brutepuppy Tubes / Valves 0 3rd July 2008 07:40 AM
Cambridge Audio 640C No audio output PLEASE HELP! Kajman Digital Source 3 10th December 2007 10:45 AM
FS: RS 1147 full range - highly modified bbaker6212 Swap Meet 0 3rd October 2002 07:02 PM
FS: RS 1147 full range - highly modified bbaker6212 Swap Meet 0 3rd October 2002 06:59 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
