Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Problem with my revox   B126 cd player no eject.....
Old 19th September 2019, 05:49 PM   #1
Bikerboy666 is offline Bikerboy666  United Kingdom
Default Problem with my revox B126 cd player no eject.....
I have a revox B126 cd player...when I press load...ie eject the tray wont eject...taking it apart i manually eject the tray with my fingers .i put a cd into the tray and press load and it goes back in...some how there seems a plastic rubing noise and i notice the top plastic piece at the top is rubbingg.when pulled up a little it starts to read the cd ...and plays..it wont eject the cd when load is pressed....ive replaced all caps on psu right hand board...what could the problem be?so to summarize it takes the cd in..it wont eject and it reads plays a cd when top plastic is pulled up slightly..thankyou for reading simon
Old 19th September 2019, 05:53 PM   #2
Mooly's Avatar
I'm not familiar with the player but 'rubbing noises' and having to give it a little helping hand to load and unload suggest maybe a loading belt is slipping somewhere. Most players use one or more in some or another.
Old 19th September 2019, 05:58 PM   #3
Thanks for quick reply .the long drive belt for liad eject is fine..not slipping..i feel the eject motor is not getting voltage from the logic board..simon
Old 19th September 2019, 07:03 PM   #4
Mooly's Avatar
You will need to study the circuit details in that case, however have you checked to see if there is any voltage across the motor. Motors can become lazy and suffer with dead spots. Also there may be a circuit protector (like a fuse) or some safety resistor that has gone open to protect the drive circuitry if the motor draws/drew excess current.
You need the circuit
Problem with my revox   B126 cd player no eject.....Hide this!Advertise here!
Revox B126 / B226 = The Usual Problem!! kevinkevin Digital Source 6 15th March 2014 12:10 PM
Help Required : Revox B126 CD Player dtm1962 Digital Source 8 27th October 2010 11:40 AM
Revox B126 CD Player Malfunction- Help Needed (TDA1541A-CDM4/27) dtm1962 Digital Source 14 16th October 2010 02:40 PM
Revox B126 CD Player Power Supply Troubleshooting Help Required dtm1962 Digital Source 3 19th September 2010 02:51 AM
Revox B126 / B226 CD Player poynton Digital Source 0 6th March 2009 06:40 AM
Copyright ©1999-2019 diyAudio
