Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Yamaha CDX993 - Display problem???
Old 7th August 2019, 06:35 PM   #1
poynton is offline poynton  United Kingdom
poynton's Avatar
Default Yamaha CDX993 - Display problem???
Hi All,
I have been given a working Yamaha CDX993.
The display is a bit dim.
Anyone know of a fix??
Thanks.
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 7th August 2019, 06:52 PM   #2
Mooly's Avatar
Not specifically. If its a VFD (Vacuum Fluorescent) then caps in the section of the PSU that generate the negative rail of around -30 volt favourites. If its one of those back-lit types beloved of Sharp and the like then probably the display itself is faulty.
Depends as well how dim is dim... worth whipping the front of and making sure the bezel and filter and the display are clean. That can gain you a fair bit.
Good luck nice player.
Old 7th August 2019, 07:11 PM   #3
poynton's Avatar
Hi.
Thanks for the reply.
I've sussed the problem and it is now OK.
Yes. It is a very nice player - sounds very good.
Andy
Old 7th August 2019, 07:14 PM   #4
Mooly's Avatar
Originally Posted by poynton View Post
...........I've sussed the problem and it is now OK.
Do tell or shouldn't we ask
Pleased to hear you sorted it anyway.
Old 8th August 2019, 11:59 AM   #5
poynton's Avatar
Bad contact!!
Old 8th August 2019, 01:32 PM   #6
Mooly's Avatar
Bad contact, and there was me wondering if it had a dimmer function
Excellent... enjoy.
Yamaha CDX993 - Display problem???Hide this!Advertise here!
Yamaha RX-730 display cyto Solid State 4 27th April 2017 05:27 PM
Yamaha RX-V595 display panel stayed on 3~5 seconds then turned off Peter Qiu Solid State 4 27th June 2016 08:29 AM
yamaha vx661 display fix unclejed613 Solid State 0 13th April 2008 06:01 PM
yamaha cdr-s1000 vacuum display replacement gmunee Digital Source 0 10th April 2005 06:00 PM
Copyright ©1999-2019 diyAudio
