Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
I2S isolation for DAC
Old 4th August 2019, 12:04 PM   #21
merlin el mago is offline merlin el mago  Europe
merlin el mago's Avatar
Originally Posted by analog_sa View Post
Yes. That is why the JLSounds use 45/49Mhz clocks.
I supposed, thanks.
Old 4th August 2019, 05:09 PM   #22
JensH is offline JensH  Denmark
Originally Posted by Colakurt View Post
I have considered the transformer solution too, but wouldnt that result in a phasshift/time delay between the MCLK and the other i2s signals? or does that not matter for an application like this?
A phase shift between MCLK and the I2S signals doesn't matter.
A transformer for MCK? Never heard of this idea. What would happen to the square wave? Would it not be worse than jitter?
If a suitable wideband trnsformer is used, the jitter can be very low. Much lower than with digital isolators.
Old 4th August 2019, 06:01 PM   #23
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
I would not anticipate jitter but rather a waveform with sloping edges. No idea what effect this would have. Can you suggest specs for a transformer or even a specific part?
Old 4th August 2019, 06:09 PM   #24
It is used in Frex's OSVA, see OSVA - Open source Versatile Analyzer
It was suggested here: SAR ADC for high performance audio ADC project [LTC2380-24]
Frex had already considered it, see a couple of posts later.
Some measurement results can be found here: SAR ADC for high performance audio ADC project [LTC2380-24]
The Würth 749010310 (LAN) seems to work very well. I am sure there are a lot of other possibilities.
Old 4th August 2019, 07:10 PM   #25
analog_sa's Avatar
Thank you!
I2S isolation for DACHide this!Advertise here!
USB DAC isolation ? soundcheck Digital Line Level 104 19th November 2012 09:47 AM
I2S isolation Koenjer Digital Line Level 6 15th December 2010 01:41 PM
PS/Amp isolation in 1 box ? jimbo1968 Chip Amps 5 20th May 2005 07:04 PM
isolation pad rulezzz Solid State 0 10th January 2004 05:25 PM
about isolation rulezzz Chip Amps 1 8th January 2004 05:36 PM
Copyright ©1999-2019 diyAudio
